YeaLink W60P
My test setup has one phone. I was able to leave a message for another extension and it worked perfectly. The pbx says it is registered with my provider, but it does not say that at the provider's end right now. It normally is done very quickly and so they are looking into why they don't see it.
I will try an outgoing call once that is done.
In any case, I believe the W60P is all set up, thanks to you. I will document this solution as a necessary step.
Many thanks. :D
Check out comment number 19.
Also, please note that I switched to Grandstream phones. More intuitive, although nothing is perfect.
