Yealink T5X DSSKey Transfer Problem
mydigitalself
71
I had lots of problems with Yealink T54W. From BLF not working to the transfer issue you are referring to. I am now using 96.86.0.15 and it has solved those problems.
Good news. Thank you. I'm testing ver 86 now a T58 and so far so good. Have you had audio issues on longer calls? One version of the ver 85 firmware created 4min gaps in audio at random. I've been running on ver 84 as a result.
On the T54W, the firmware does not appear on Yealink's site as of yet. Do you happen to have a copy of this firmware?
gflow
268
31
There's newer firmer than that on the Yealink site, they are up to: T54W(T57W,T53W,T53,T53C,T54,T57)-96.86.0.23.rom
They've just uploaded it a little differently this time because they needed to attach some important upgrade notes. Check this link:
and click on this file name "T5X New Firmware(Please read the Upgrade Guide before upgrading ).zip"
