Yealink and Wifi
SlimJim
11
Northern Indiana
We are building out a site where 5 of our Yealink phones will be connected via Wifi. We have already done a Wifi audit to make sure they will work fine on wifi. But my question is, is there an simple way to connect these phones to wifi without having to enter the wifi on each phone? I see that Yealink has a wifi assistant, but I could not get that to work, and I question its use altogether. I know I can program the Wifi in the provisioning, but I would like to be able to setup a way that when we plug in the phone for the first time, it will auto connect to the network, and then send its provisioning request.
s2svoip
259
you want to auto-provision a phone to give it wifi credentials before connecting it to a network?
it needs network access to first get its auto-provision info...
381
You could keep a short config file to load in manually with just that detail in it...
#!version:1.0.0.1
### This file is the exported MAC-all.cfg.
###  Static Configuration  ###
static.auto_provision.server.url = https://mypbx.co.uk/app/provision
static.auto_provision.server.username = ProvUserName
static.auto_provision.server.password = prov-password
static.network.wifi.internet_port.type = 0
static.network.wifi.ip_address_mode = 0
static.network.wifi.ipv6_icmp_v6.enable = 1
static.network.wifi.ipv6_internet_port.type = 0
static.network.wifi.ipv6_prefix = 64
static.network.wifi.ipv6_static_dns_enable = 0
static.network.wifi.preference = 0
static.network.wifi.static_dns_enable = 0
static.wifi.1.cipher_type = CCMP
static.wifi.1.label = MyWirelessNetwork
static.wifi.1.security_mode = WPA2-PSK
static.wifi.1.ssid = mywifi
static.wifi.1.password = mywifipassword
static.wifi.enable = 1
