Unable to Receive Any Calls
man
Now is it okay. I have reloaded the ACL again same issue
I am new to this platform
this is the logs
2020-10-24 09:43:54.423235 [NOTICE] switch_channel.c:1118 New Channel sofia/external/8003713030@162.212.219.195 [3eabeb44-559d-4a91-929d-dcb09403debd]
2020-10-24 09:43:54.423235 [DEBUG] switch_core_state_machine.c:585 (sofia/external/8003713030@162.212.219.195) Running State Change CS_NEW (Cur 3 Tot 33645)
2020-10-24 09:43:54.423235 [DEBUG] sofia.c:10280 sofia/external/8003713030@162.212.219.195 receiving invite from 162.212.218.50:5060 version: 1.10.5 -release.8 64bit
2020-10-24 09:43:54.423235 [DEBUG] sofia.c:10374 verifying acl "domains" for ip/port 162.212.218.50:0.
2020-10-24 09:43:54.423235 [DEBUG] switch_core_state_machine.c:604 (sofia/external/8003713030@162.212.219.195) State NEW
send 827 bytes to udp/[162.212.218.50]:5060 at 09:43:54.427132:
Via: SIP/2.0/UDP 162.xx.xxx.50;branch=z9hG4bKaa43.24f45581b7df5dc345b81ff14f029ffd.0
Via: SIP/2.0/UDP 162.xxx.xxx.195:5004;received=162.212.219.195;rport=5004;branch=z9hG4bK86a0Frt2BjUQa
From: "8003713030" <sip:8003713030@1xx.xx.xx.195>;tag=F38g6BgX0D65g
To: <sip:18003713030@45.34.23.218:5080>;tag=N2vtj0SerKvaQ
Call-ID: cc8784bb-90a1-1239-bdb4-fa163e0b9671
CSeq: 27219725 INVITE
User-Agent: FreeSWITCH-mod_sofia/1.10.5-release.8~64bit
Accept: application/sdp
Proxy-Authenticate: Digest realm="45.34.23.218", nonce="15840732-2a18-49c1-8a85-2b9be69ff223", algorithm=MD5, qop="auth"
man
I have attached the inbound gateway configuration and inbound routes configuration. Please correct me
579
Right, I'm close to giving up on you here, YOUR CARRIER IPs need to be in th ACL, you obscure the image but the ONLY ip I see in there ends in .11 The IP being challenged in the picture above is 162.212.218.50
Why is that not in the ACL?
man
this is the carrier Ip
I dont from where this ip coming 162.212.218.50
579
Well that is where it is coming from, maybe the carrier just has multiple servers.
man
Which ip should I add now and where should I add
The sip provider is providing only one ip
Please help me
man
I have added this Ip in ACL now this error
2020/10/24 20:33:04.110483 45.34.23.218:5080 -> 162.212.218.50:5060
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 162.212.218.50;branch=z9hG4bKc19a.a67e39ada339083b6ea1585d470b52d1.0
Via: SIP/2.0/UDP 162.212.219.195:5004;received=162.212.219.195;rport=5004;branch=z9hG4bK3ympDQXZjpatQ
Max-Forwards: 66
From: "8003713030" <sip:8003713030@162.212.219.195>;tag=maSyD883yrc2N
To: <sip:18003713030@45.34.23.218:5080>;tag=NmZ1g00XQZvUQ
Call-ID: 7c58a229-90fc-1239-bdb4-fa163e0b9671
CSeq: 27239200 INVITE
Reason: Q.850;cause=3;text="NO_ROUTE_DESTINATION"
Content-Length: 0
Remote-Party-ID: "18003713030" <sip:18003713030@45.34.23.218>;party=calling;privacy=off;screen=no
man
Actually, I am using two gateways one for outbound and one for inbound.
is it causing any issue?
Also, I have talked to the carrier they are forwarding all the incoming call on 5080 port
please help in this
579
You did not paste enough of the log but I think it is to do with your destination being for 8xx when it should be 18xx or the other way around.
man
This is the destination
can you please check need to change something here
man
this is the log please check
OK log level [7]
send 719 bytes to udp/[167.114.0.41]:5060 at 04:36:30.219556:
Via: SIP/2.0/UDP 37.202.240.156:5060;branch=z9hG4bK-524287-1---k5cyv1ngztg49l8z;received=167.114.0.41
From: <sip:214@45.34.23.218;transport=UDP>;tag=5j0xmmza
To: <sip:00447537174009@45.34.23.218;transport=UDP>;tag=rcH9443gN61Sr
Call-ID: vaSYn3dWGK06zfTXQRRQpK..
CSeq: 1 INVITE
Proxy-Authenticate: Digest realm="45.34.23.218", nonce="4136fe6c-401b-4d20-af92-9c00a371cc46", algorithm=MD5, qop="auth"
Content-Length: 0
send 719 bytes to udp/[167.114.0.41]:5060 at 04:36:34.220363:
CSeq: 1 INVITE
Content-Length: 0
recv 791 bytes from udp/[167.114.0.41]:37981 at 04:36:37.795439:
INVITE sip:00447537174009@45.34.23.218:5080;transport=UDP SIP/2.0
Via: SIP/2.0/UDP 67.201.72.230:5060;branch=z9hG4bK-524287-1---cmapcydr9735g705
Max-Forwards: 70
Contact: <sip:215@67.201.72.230:5060;transport=UDP>
From: <sip:215@45.34.23.218;transport=UDP>;tag=9l1d28fv
Call-ID: tuZFmSe2HKyEKUdBnFQoYx..
CSeq: 1 INVITE
Content-Type: application/sdp
User-Agent: Z 3.14.38765 rv2.8.3
Allow-Events: presence, kpml, talk
Content-Length: 288
v=0
o=Z 0 0 IN IP4 67.201.72.230
s=Z
c=IN IP4 67.201.72.230
t=0 0
m=audio 8000 RTP/AVP 18 3 110 8 0 97 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:110 speex/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=fmtp:101 0-16
a=sendrecv
2020-10-25 04:36:37.783090 [NOTICE] switch_channel.c:1118 New Channel sofia/external/215@45.34.23.218 [d97af739-290e-4f56-8e90-4be08de9ce3c]
2020-10-25 04:36:37.783090 [DEBUG] switch_core_state_machine.c:585 (sofia/external/215@45.34.23.218) Running State Change CS_NEW (Cur 1 Tot 35190)
2020-10-25 04:36:37.783090 [DEBUG] sofia.c:10280 sofia/external/215@45.34.23.218 receiving invite from 167.114.0.41:37981 version: 1.10.5 -release.8 64bit
2020-10-25 04:36:37.783090 [DEBUG] sofia.c:10374 verifying acl "domains" for ip/port 167.114.0.41:0.
2020-10-25 04:36:37.783090 [DEBUG] switch_core_state_machine.c:604 (sofia/external/215@45.34.23.218) State NEW
send 718 bytes to udp/[167.114.0.41]:5060 at 04:36:37.797895:
Via: SIP/2.0/UDP 67.201.72.230:5060;branch=z9hG4bK-524287-1---cmapcydr9735g705;received=167.114.0.41
To: <sip:00447537174009@45.34.23.218;transport=UDP>;tag=SNa26ZmmjFrcm
CSeq: 1 INVITE
Proxy-Authenticate: Digest realm="45.34.23.218", nonce="29dd016f-b3b0-4d91-893b-5e937a22351a", algorithm=MD5, qop="auth"
Content-Length: 0
2020-10-25 04:36:37.783090 [DEBUG] sofia.c:2434 detaching session d97af739-290e-4f56-8e90-4be08de9ce3c
send 719 bytes to udp/[167.114.0.41]:5060 at 04:36:38.221897:
CSeq: 1 INVITE
Content-Length: 0
send 718 bytes to udp/[167.114.0.41]:5060 at 04:36:38.298184:
CSeq: 1 INVITE
Content-Length: 0
send 718 bytes to udp/[167.114.0.41]:5060 at 04:36:39.298824:
CSeq: 1 INVITE
Content-Length: 0
send 718 bytes to udp/[167.114.0.41]:5060 at 04:36:41.299212:
CSeq: 1 INVITE
Content-Length: 0
send 719 bytes to udp/[167.114.0.41]:5060 at 04:36:42.223299:
CSeq: 1 INVITE
Content-Length: 0
send 718 bytes to udp/[167.114.0.41]:5060 at 04:36:45.300333:
CSeq: 1 INVITE
Content-Length: 0
send 719 bytes to udp/[167.114.0.41]:5060 at 04:36:46.224436:
CSeq: 1 INVITE
Content-Length: 0
2020-10-25 04:36:47.883259 [WARNING] switch_core_state_machine.c:688 d97af739-290e-4f56-8e90-4be08de9ce3c sofia/external/215@45.34.23.218 Abandoned
2020-10-25 04:36:47.883259 [NOTICE] switch_core_state_machine.c:691 Hangup sofia/external/215@45.34.23.218 [CS_NEW] [WRONG_CALL_STATE]
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:585 (sofia/external/215@45.34.23.218) Running State Change CS_HANGUP (Cur 1 Tot 35190)
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:848 (sofia/external/215@45.34.23.218) Callstate Change DOWN -> HANGUP
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:850 (sofia/external/215@45.34.23.218) State HANGUP
2020-10-25 04:36:47.883259 [DEBUG] mod_sofia.c:453 Channel sofia/external/215@45.34.23.218 hanging up, cause: WRONG_CALL_STATE
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:60 sofia/external/215@45.34.23.218 Standard HANGUP, cause: WRONG_CALL_STATE
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:850 (sofia/external/215@45.34.23.218) State HANGUP going to sleep
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:620 (sofia/external/215@45.34.23.218) State Change CS_HANGUP -> CS_REPORTING
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:585 (sofia/external/215@45.34.23.218) Running State Change CS_REPORTING (Cur 1 Tot 35190)
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:936 (sofia/external/215@45.34.23.218) State REPORTING
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:174 sofia/external/215@45.34.23.218 Standard REPORTING, cause: WRONG_CALL_STATE
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:936 (sofia/external/215@45.34.23.218) State REPORTING going to sleep
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:611 (sofia/external/215@45.34.23.218) State Change CS_REPORTING -> CS_DESTROY
2020-10-25 04:36:47.883259 [DEBUG] switch_core_session.c:1726 Session 35190 (sofia/external/215@45.34.23.218) Locked, Waiting on external entities
2020-10-25 04:36:47.883259 [NOTICE] switch_core_session.c:1744 Session 35190 (sofia/external/215@45.34.23.218) Ended
2020-10-25 04:36:47.883259 [NOTICE] switch_core_session.c:1748 Close Channel sofia/external/215@45.34.23.218 [CS_DESTROY]
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:739 (sofia/external/215@45.34.23.218) Running State Change CS_DESTROY (Cur 0 Tot 35190)
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:749 (sofia/external/215@45.34.23.218) State DESTROY
2020-10-25 04:36:47.883259 [DEBUG] mod_sofia.c:364 sofia/external/215@45.34.23.218 SOFIA DESTROY
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:181 sofia/external/215@45.34.23.218 Standard DESTROY
2020-10-25 04:36:47.883259 [DEBUG] switch_core_state_machine.c:749 (sofia/external/215@45.34.23.218) State DESTROY going to sleep
send 718 bytes to udp/[167.114.0.41]:5060 at 04:36:49.302264:
CSeq: 1 INVITE
Content-Length: 0
send 718 bytes to udp/[167.114.0.41]:5060 at 04:36:53.302861:
CSeq: 1 INVITE
Content-Length: 0
recv 7240 bytes from wss/[106.211.82.139]:51263 at 04:36:53.386393:
INVITE sip:+18003713030@45.34.23.218 SIP/2.0
Via: SIP/2.0/WSS atn4hnohkirb.invalid;branch=z9hG4bK6587020
Max-Forwards: 69
To: <sip:+18003713030@45.34.23.218>
Call-ID: e485n5cghbcvta7ruqpo
CSeq: 9786 INVITE
Contact: <sip:p1arrlk2@atn4hnohkirb.invalid;transport=ws;ob>
Allow: INVITE,ACK,CANCEL,BYE,UPDATE,MESSAGE,OPTIONS,REFER,INFO,NOTIFY
Supported: ice,replaces,outbound
User-Agent: JsSIP 3.5.8
Content-Length: 6729
v=0
o=- 7206732058553084982 2 IN IP4 127.0.0.1
s=-
t=0 0
a=group:BUNDLE 0 1
a=msid-semantic: WMS SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk
m=audio 6569 UDP/TLS/RTP/SAVPF 111 103 104 9 0 8 106 105 13 110 112 113 126
c=IN IP4 106.211.82.139
a=rtcp:49288 IN IP4 106.211.82.139
a=candidate:2633341356 1 udp 2122260223 172.20.10.6 36266 typ host generation 0 network-id 1 network-cost 10
a=candidate:2633341356 2 udp 2122260222 172.20.10.6 51782 typ host generation 0 network-id 1 network-cost 10
a=candidate:3530974556 1 tcp 1518280447 172.20.10.6 9 typ host tcptype active generation 0 network-id 1 network-cost 10
a=candidate:3530974556 2 tcp 1518280446 172.20.10.6 9 typ host tcptype active generation 0 network-id 1 network-cost 10
a=candidate:900339321 1 udp 1686052607 106.211.82.139 6569 typ srflx raddr 172.20.10.6 rport 36266 generation 0 network-id 1 network-cost 10
a=candidate:900339321 2 udp 1686052606 106.211.82.139 49288 typ srflx raddr 172.20.10.6 rport 51782 generation 0 network-id 1 network-cost 10
a=ice-ufrag:NeTm
a=ice-pwd:l0Md2ILhmJGA4eluKKkBdPVs
a=ice-options:trickle
a=fingerprint:sha-256 17:49:C2:3F:74:AC:2A:53:EF:F8:61:35:3D:B7:70:BC:85:8D:66:9B:16:2F:7A:99:6A:51:11:0C:3E:E9:B2:A0
a=setup:actpass
a=mid:0
a=extmap:1 urn:ietf:params:rtp-hdrext:ssrc-audio-level
a=extmap:2 http://www.webrtc.org/experiments/rtp-hdrext/abs-send-time
a=extmap:3 http://www.ietf.org/id/draft-holmer-rmcat-transport-wide-cc-extensions-01
a=extmap:4 urn:ietf:params:rtp-hdrext:sdes:mid
a=extmap:5 urn:ietf:params:rtp-hdrext:sdes:rtp-stream-id
a=extmap:6 urn:ietf:params:rtp-hdrext:sdes:repaired-rtp-stream-id
a=sendrecv
a=msid:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk e9e39370-d669-4179-ade3-c71991cf02ad
a=rtcp-mux
a=rtpmap:111 opus/48000/2
a=rtcp-fb:111 transport-cc
a=fmtp:111 minptime=10;useinbandfec=1
a=rtpmap:103 ISAC/16000
a=rtpmap:104 ISAC/32000
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:106 CN/32000
a=rtpmap:105 CN/16000
a=rtpmap:13 CN/8000
a=rtpmap:110 telephone-event/48000
a=rtpmap:112 telephone-event/32000
a=rtpmap:113 telephone-event/16000
a=rtpmap:126 telephone-event/8000
a=ssrc:1368644088 cname:5V/huSgSRGM8hMfu
a=ssrc:1368644088 msid:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk e9e39370-d669-4179-ade3-c71991cf02ad
a=ssrc:1368644088 mslabel:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk
a=ssrc:1368644088 label:e9e39370-d669-4179-ade3-c71991cf02ad
m=video 49289 UDP/TLS/RTP/SAVPF 96 97 98 99 100 101 102 121 127 120 125 107 108 109 124 119 123
a=rtcp:44771 IN IP4 106.211.82.139
a=candidate:2633341356 1 udp 2122260223 172.20.10.6 59740 typ host generation 0 network-id 1 network-cost 10
a=candidate:2633341356 2 udp 2122260222 172.20.10.6 40742 typ host generation 0 network-id 1 network-cost 10
a=candidate:900339321 2 udp 1686052606 106.211.82.139 44771 typ srflx raddr 172.20.10.6 rport 40742 generation 0 network-id 1 network-cost 10
a=candidate:900339321 1 udp 1686052607 106.211.82.139 49289 typ srflx raddr 172.20.10.6 rport 59740 generation 0 network-id 1 network-cost 10
a=ice-ufrag:NeTm
a=setup:actpass
a=mid:1
a=extmap:14 urn:ietf:params:rtp-hdrext:toffset
a=extmap:13 urn:3gpp:video-orientation
a=extmap:12 http://www.webrtc.org/experiments/rtp-hdrext/playout-delay
a=extmap:11 http://www.webrtc.org/experiments/rtp-hdrext/video-content-type
a=extmap:7 http://www.webrtc.org/experiments/rtp-hdrext/video-timing
a=extmap:8 http://www.webrtc.org/experiments/rtp-hdrext/color-space
a=sendrecv
a=msid:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk bf40cee3-ff6b-4dc2-9448-26a60ff33494
a=rtcp-mux
a=rtcp-rsize
a=rtpmap:96 VP8/90000
a=rtcp-fb:96 goog-remb
a=rtcp-fb:96 transport-cc
a=rtcp-fb:96 ccm fir
a=rtcp-fb:96 nack
a=rtcp-fb:96 nack pli
a=rtpmap:97 rtx/90000
a=fmtp:97 apt=96
a=rtpmap:98 VP9/90000
a=rtcp-fb:98 goog-remb
a=rtcp-fb:98 transport-cc
a=rtcp-fb:98 ccm fir
a=rtcp-fb:98 nack
a=rtcp-fb:98 nack pli
a=fmtp:98 profile-id=0
a=rtpmap:99 rtx/90000
a=fmtp:99 apt=98
a=rtpmap:100 VP9/90000
a=rtcp-fb:100 goog-remb
a=rtcp-fb:100 transport-cc
a=rtcp-fb:100 ccm fir
a=rtcp-fb:100 nack
a=rtcp-fb:100 nack pli
a=fmtp:100 profile-id=2
a=rtpmap:101 rtx/90000
a=fmtp:101 apt=100
a=rtpmap:102 H264/90000
a=rtcp-fb:102 goog-remb
a=rtcp-fb:102 transport-cc
a=rtcp-fb:102 ccm fir
a=rtcp-fb:102 nack
a=rtcp-fb:102 nack pli
a=fmtp:102 level-asymmetry-allowed=1;packetization-mode=1;profile-level-id=42001f
a=rtpmap:121 rtx/90000
a=fmtp:121 apt=102
a=rtpmap:127 H264/90000
a=rtcp-fb:127 goog-remb
a=rtcp-fb:127 transport-cc
a=rtcp-fb:127 ccm fir
a=rtcp-fb:127 nack
a=rtcp-fb:127 nack pli
a=fmtp:127 level-asymmetry-allowed=1;packetization-mode=0;profile-level-id=42001f
a=rtpmap:120 rtx/90000
a=fmtp:120 apt=127
a=rtpmap:125 H264/90000
a=rtcp-fb:125 goog-remb
a=rtcp-fb:125 transport-cc
a=rtcp-fb:125 ccm fir
a=rtcp-fb:125 nack
a=rtcp-fb:125 nack pli
a=fmtp:125 level-asymmetry-allowed=1;packetization-mode=1;profile-level-id=42e01f
a=rtpmap:107 rtx/90000
a=fmtp:107 apt=125
a=rtpmap:108 H264/90000
a=rtcp-fb:108 goog-remb
a=rtcp-fb:108 transport-cc
a=rtcp-fb:108 ccm fir
a=rtcp-fb:108 nack
a=rtcp-fb:108 nack pli
a=fmtp:108 level-asymmetry-allowed=1;packetization-mode=0;profile-level-id=42e01f
a=rtpmap:109 rtx/90000
a=fmtp:109 apt=108
a=rtpmap:124 red/90000
a=rtpmap:119 rtx/90000
a=fmtp:119 apt=124
a=rtpmap:123 ulpfec/90000
a=ssrc-group:FID 2063360914 1169189933
a=ssrc:2063360914 cname:5V/huSgSRGM8hMfu
a=ssrc:2063360914 msid:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk bf40cee3-ff6b-4dc2-9448-26a60ff33494
a=ssrc:2063360914 mslabel:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk
a=ssrc:2063360914 label:bf40cee3-ff6b-4dc2-9448-26a60ff33494
a=ssrc:1169189933 cname:5V/huSgSRGM8hMfu
a=ssrc:1169189933 msid:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk bf40cee3-ff6b-4dc2-9448-26a60ff33494
a=ssrc:1169189933 mslabel:SvUoX3He1rv5jgvWHxhigpfdGcch1LtyDTBk
a=ssrc:1169189933 label:bf40cee3-ff6b-4dc2-9448-26a60ff33494
2020-10-25 04:36:53.383268 [NOTICE] switch_channel.c:1118 New Channel sofia/internal/20@45.34.23.218 [1ca88063-e1ed-4137-8188-db0b73577e3c]
2020-10-25 04:36:53.383268 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/20@45.34.23.218) Running State Change CS_NEW (Cur 1 Tot 35191)
2020-10-25 04:36:53.383268 [DEBUG] sofia.c:10280 sofia/internal/20@45.34.23.218 receiving invite from 106.211.82.139:51263 version: 1.10.5 -release.8 64bit
2020-10-25 04:36:53.383268 [DEBUG] sofia.c:10374 verifying acl "domains" for ip/port 106.211.82.139:0.
2020-10-25 04:36:53.463268 [WARNING] sofia_reg.c:1794 SIP auth challenge (INVITE) on sofia profile 'internal' for [+18003713030@45.34.23.218] from ip 106.211.82.139
2020-10-25 04:36:53.463268 [DEBUG] switch_core_state_machine.c:604 (sofia/internal/20@45.34.23.218) State NEW
send 804 bytes to wss/[106.211.82.139]:51263 at 04:36:53.474859:
Via: SIP/2.0/WSS atn4hnohkirb.invalid;branch=z9hG4bK6587020;received=106.211.82.139;rport=51263
To: <sip:+18003713030@45.34.23.218>;tag=UvXZ59Uc838vg
CSeq: 9786 INVITE
Proxy-Authenticate: Digest realm="45.34.23.218", nonce="0f72e593-c2e6-4960-8ba6-90fa5845b022", algorithm=MD5, qop="auth"
Content-Length: 0
2020-10-25 04:36:53.463268 [DEBUG] sofia.c:2434 detaching session 1ca88063-e1ed-4137-8188-db0b73577e3c
recv 414 bytes from wss/[106.211.82.139]:51263 at 04:36:53.780798:
ACK sip:+18003713030@45.34.23.218 SIP/2.0
Max-Forwards: 69
CSeq: 9786 ACK
Supported: outbound
Content-Length: 0
recv 7494 bytes from wss/[106.211.82.139]:51263 at 04:36:53.786554:
Via: SIP/2.0/WSS atn4hnohkirb.invalid;branch=z9hG4bK5839952
Max-Forwards: 69
CSeq: 9787 INVITE
Proxy-Authorization: Digest algorithm=MD5, username="20", realm="45.34.23.218", nonce="0f72e593-c2e6-4960-8ba6-90fa5845b022", uri="sip:+18003713030@45.34.23.218", response="c84cfbb7758719a5fcfa77bbed2bc3f3", qop=auth, cnonce="dsfn4pt08snl", nc=00000001
v=0
s=-
t=0 0
a=group:BUNDLE 0 1
a=ice-ufrag:NeTm
a=setup:actpass
a=mid:0
a=sendrecv
a=rtcp-mux
a=rtpmap:13 CN/8000
a=ice-ufrag:NeTm
a=setup:actpass
a=mid:1
a=sendrecv
a=rtcp-mux
a=rtcp-rsize
a=rtcp-fb:96 nack
a=fmtp:97 apt=96
a=rtcp-fb:98 nack
a=fmtp:99 apt=98
a=rtcp-fb:100 nack
a=fmtp:101 apt=100
a=rtcp-fb:102 nack
a=fmtp:121 apt=102
a=rtcp-fb:127 nack
a=fmtp:120 apt=127
a=rtcp-fb:125 nack
a=fmtp:107 apt=125
a=rtcp-fb:108 nack
a=fmtp:109 apt=108
a=fmtp:119 apt=124
2020-10-25 04:36:53.783089 [DEBUG] sofia.c:2544 Re-attaching to session 1ca88063-e1ed-4137-8188-db0b73577e3c
2020-10-25 04:36:53.783089 [DEBUG] sofia.c:10280 sofia/internal/20@45.34.23.218 receiving invite from 106.211.82.139:51263 version: 1.10.5 -release.8 64bit
2020-10-25 04:36:53.783089 [DEBUG] sofia.c:10374 verifying acl "domains" for ip/port 106.211.82.139:0.
2020-10-25 04:36:54.303243 [DEBUG] sofia.c:11477 Setting NAT mode based on via received
2020-10-25 04:36:54.303243 [DEBUG] sofia.c:7326 Channel sofia/internal/20@45.34.23.218 entering state [received][100]
2020-10-25 04:36:54.303243 [DEBUG] sofia.c:7336 Remote SDP:
v=0
s=-
t=0 0
a=group:BUNDLE 0 1
a=rtpmap:13 CN/8000
a=ice-ufrag:NeTm
a=setup:actpass
a=mid:0
a=rtcp-mux
a=fmtp:97 apt=96
a=fmtp:99 apt=98
a=fmtp:101 apt=100
a=fmtp:121 apt=102
a=fmtp:120 apt=127
a=fmtp:107 apt=125
a=fmtp:109 apt=108
a=fmtp:119 apt=124
a=ice-ufrag:NeTm
a=setup:actpass
a=mid:1
a=rtcp-mux
a=rtcp-rsize
a=rtcp-fb:96 nack
a=rtcp-fb:98 nack
a=rtcp-fb:100 nack
a=rtcp-fb:102 nack
a=rtcp-fb:127 nack
a=rtcp-fb:125 nack
a=rtcp-fb:108 nack
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [opus:111:48000:20:0:2]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [opus:111:48000:20:0:2]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [opus:111:48000:20:0:2]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [opus:111:48000:20:0:2]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [opus:111:48000:20:0:2]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:103:16000:30:32000:1]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:103:16000:30:32000:1]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:103:16000:30:32000:1]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:103:16000:30:32000:1]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:103:16000:30:32000:1]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:104:32000:30:32000:1]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:104:32000:30:32000:1]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:104:32000:30:32000:1]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:104:32000:30:32000:1]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [ISAC:104:32000:30:32000:1]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [G722:9:8000:20:64000:1] ++++ is saved as a match
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [G722:9:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:105:16000:20:0:1]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:105:16000:20:0:1]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:105:16000:20:0:1]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:105:16000:20:0:1]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:105:16000:20:0:1]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:13:8000:20:0:1]/[G7221:115:32000:20:48000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:13:8000:20:0:1]/[G7221:107:16000:20:32000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:13:8000:20:0:1]/[G722:9:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:13:8000:20:0:1]/[PCMU:0:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [CN:13:8000:20:0:1]/[PCMA:8:8000:20:64000:1]
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5510 Set telephone-event payload to 110@48000
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:3839 Set Codec sofia/internal/20@45.34.23.218 G722/8000 20 ms 160 samples 64000 bits 1 channels
2020-10-25 04:36:54.303243 [DEBUG] switch_core_codec.c:111 sofia/internal/20@45.34.23.218 Original read codec set to G722:9
2020-10-25 04:36:54.303243 [WARNING] switch_core_media.c:4254 NO candidate ACL defined, Defaulting to wan.auto
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4284 Save audio Candidate cid: 1 proto: udp type: host addr: 172.20.10.6:36266
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4284 Save audio Candidate cid: 2 proto: udp type: host addr: 172.20.10.6:51782
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4284 Save audio Candidate cid: 1 proto: udp type: srflx addr: 106.211.82.139:6569
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4284 Save audio Candidate cid: 2 proto: udp type: srflx addr: 106.211.82.139:49288
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4329 Searching for rtp candidate.
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4338 Choose rtp candidate, index 1, 106.211.82.139:6569
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4104 sofia/internal/20@45.34.23.218 choosing family v4
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4349 Choose same candidate, index 2, for rtcp based on rtcp-mux attribute 106.211.82.139:6569
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4401 setting remote audio ice addr to index 1 106.211.82.139:6569 based on candidate
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:4436 Setting remote rtcp audio addr to 106.211.82.139:6569 based on candidate
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5853 Set telephone-event payload to 126@8000
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:5911 sofia/internal/20@45.34.23.218 Set 2833 dtmf send payload to 126 recv payload to 126
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:6239 No matches with FTMP, fallback to ignoring FMTP
2020-10-25 04:36:54.303243 [DEBUG] switch_core_media.c:6247 No matches with inherit_codec, fallback to ignoring PT
2020-10-25 04:36:54.303243 [DEBUG] sofia.c:7760 (sofia/internal/20@45.34.23.218) State Change CS_NEW -> CS_INIT
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/20@45.34.23.218) Running State Change CS_INIT (Cur 1 Tot 35191)
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/20@45.34.23.218) State INIT
2020-10-25 04:36:54.303243 [DEBUG] mod_sofia.c:93 sofia/internal/20@45.34.23.218 SOFIA INIT
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:40 sofia/internal/20@45.34.23.218 Standard INIT
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/20@45.34.23.218) State Change CS_INIT -> CS_ROUTING
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/20@45.34.23.218) State INIT going to sleep
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/20@45.34.23.218) Running State Change CS_ROUTING (Cur 1 Tot 35191)
2020-10-25 04:36:54.303243 [DEBUG] switch_channel.c:2332 (sofia/internal/20@45.34.23.218) Callstate Change DOWN -> RINGING
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/20@45.34.23.218) State ROUTING
2020-10-25 04:36:54.303243 [DEBUG] mod_sofia.c:154 sofia/internal/20@45.34.23.218 SOFIA ROUTING
2020-10-25 04:36:54.303243 [DEBUG] switch_core_state_machine.c:236 sofia/internal/20@45.34.23.218 Standard ROUTING
2020-10-25 04:36:54.303243 [INFO] mod_dialplan_xml.c:637 Processing manoj <20>->+18003713030 in context 45.34.23.218
send 301 bytes to wss/[106.211.82.139]:51263 at 04:36:54.316073:
SIP/2.0 100 Trying
Via: SIP/2.0/WSS atn4hnohkirb.invalid;branch=z9hG4bK5839952;received=106.211.82.139;rport=51263
CSeq: 9787 INVITE
Content-Length: 0
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->user_exists] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_exists] ${loopback_leg}() =~ /^B$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [user_exists] () =~ // break=on-false
Dialplan: sofia/internal/20@45.34.23.218 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(user_exists=false)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [user_exists]=[false]
Dialplan: sofia/internal/20@45.34.23.218 Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(from_user_exists=true)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [from_user_exists]=[true]
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->caller-details] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Action set(caller_destination=${destination_number}) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(caller_destination=+18003713030)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [caller_destination]=[+18003713030]
Dialplan: sofia/internal/20@45.34.23.218 Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(caller_id_name=20)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [caller_id_name]=[20]
Dialplan: sofia/internal/20@45.34.23.218 Action set(caller_id_number=${caller_id_number})
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call-direction] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-direction] ${call_direction}() =~ /^(inbound|outbound|local)$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 ANTI-Action export(call_direction=local) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 export(call_direction=local)
2020-10-25 04:36:54.323121 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [call_direction]=[local]
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->global-variables] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [global-variables] () =~ // break=on-false
Dialplan: sofia/internal/20@45.34.23.218 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->domain-variables] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [domain-variables] () =~ // break=on-false
Dialplan: sofia/internal/20@45.34.23.218 Action export(origination_callee_id_name=${destination_number})
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call-limit] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-limit] ${call_direction}(local) =~ /^(inbound|outbound)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->is_loopback] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [is_loopback] ${is_follow_me_loopback}() =~ /true/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->user_record] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^inbound$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${call_direction}(local) =~ /^outbound$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [user_record] ${call_direction}(local) =~ /^local$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(from_user_record=)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [from_user_record]=[UNDEF]
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->redial] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [redial] destination_number(+18003713030) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [redial] () =~ // break=never
Dialplan: sofia/internal/20@45.34.23.218 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->speed_dial] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [speed_dial] destination_number(+18003713030) =~ /^\*0(.*)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->default_caller_id] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(emergency_caller_id_name=)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [emergency_caller_id_name]=[UNDEF]
Dialplan: sofia/internal/20@45.34.23.218 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(emergency_caller_id_number=)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [emergency_caller_id_number]=[UNDEF]
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [default_caller_id] ${outbound_caller_id_number}(+18003713030) =~ /^$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->user_hold_music] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_hold_music] ${hold_music}(local_stream://default) =~ /^$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [user_hold_music] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->route_usa] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [route_usa] ${user_exists}(false) =~ /false/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 Regex (PASS) [route_usa] destination_number(+18003713030) =~ /^\+?(\d{10,13})$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 Action set(sip_h_X-accountcode=${accountcode})
Dialplan: sofia/internal/20@45.34.23.218 Action export(call_direction=outbound)
Dialplan: sofia/internal/20@45.34.23.218 Action unset(call_timeout)
Dialplan: sofia/internal/20@45.34.23.218 Action set(hangup_after_bridge=true)
Dialplan: sofia/internal/20@45.34.23.218 Action set(effective_caller_id_name=${outbound_caller_id_name})
Dialplan: sofia/internal/20@45.34.23.218 Action set(effective_caller_id_number=${outbound_caller_id_number})
Dialplan: sofia/internal/20@45.34.23.218 Action set(inherit_codec=true)
Dialplan: sofia/internal/20@45.34.23.218 Action set(ignore_display_updates=true)
Dialplan: sofia/internal/20@45.34.23.218 Action set(callee_id_number=18003713030)
Dialplan: sofia/internal/20@45.34.23.218 Action set(continue_on_fail=true)
Dialplan: sofia/internal/20@45.34.23.218 Action set(proxy_media=false)
Dialplan: sofia/internal/20@45.34.23.218 Action set(bypass_media=false)
Dialplan: sofia/internal/20@45.34.23.218 Action set(provider_prefix=021001)
Dialplan: sofia/internal/20@45.34.23.218 Action bridge(sofia/gateway/ebcf1e9f-d639-48ba-927f-5d069bd8d0b8/02100118003713030)
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->Main] continue=
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [Main] destination_number(+18003713030) =~ /^600$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->agent_status] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [agent_status] destination_number(+18003713030) =~ /^\*22$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [agent_status] destination_number(+18003713030) =~ /^(agent\+)(.*)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->agent_status_id] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [agent_status_id] destination_number(+18003713030) =~ /^\*23$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->group-intercept] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [group-intercept] destination_number(+18003713030) =~ /^\*8$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->page-extension] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [page-extension] destination_number(+18003713030) =~ /^\*8(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->eavesdrop] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [eavesdrop] destination_number(+18003713030) =~ /^\*33(\d{2,7})$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call_privacy] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call_privacy] destination_number(+18003713030) =~ /^\*67(\d+)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call_return] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call_return] destination_number(+18003713030) =~ /^\*69$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->intercept-ext-polycom] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [intercept-ext-polycom] destination_number(+18003713030) =~ /^\*97(\d+)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->intercept-ext] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [intercept-ext] destination_number(+18003713030) =~ /^\*\*(\d+)$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [intercept-ext] destination_number(+18003713030) =~ /^\*\*$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->extension_queue] continue=
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [extension_queue] destination_number(+18003713030) =~ /^\*800(.*)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->dx] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [dx] destination_number(+18003713030) =~ /^dx$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->att_xfer] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [att_xfer] destination_number(+18003713030) =~ /^att_xfer$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->extension-to-voicemail] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->send_to_voicemail] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [send_to_voicemail] destination_number(+18003713030) =~ /^\*99(\d{2,10})$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->vmain] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [vmain] destination_number(+18003713030) =~ /^vmain$|^\*4000$|^\*98$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [vmain] destination_number(+18003713030) =~ /^(vmain$|^\*4000$|^\*98)(\d{2,12})$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->xfer_vm] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [xfer_vm] destination_number(+18003713030) =~ /^xfer_vm$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->vmain_user] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [vmain_user] destination_number(+18003713030) =~ /^\*97$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->is_transfer] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [is_transfer] destination_number(+18003713030) =~ /^is_transfer$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->delay_echo] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [delay_echo] destination_number(+18003713030) =~ /^\*9195$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->cf] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [cf] destination_number(+18003713030) =~ /^cf$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->echo] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [echo] destination_number(+18003713030) =~ /^\*9196$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->is_zrtp_secure] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 ANTI-Action eval(not_secure)
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->milliwatt] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [milliwatt] destination_number(+18003713030) =~ /^\*9197$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->is_secure] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [is_secure] ${sip_via_protocol}(wss) =~ /tls/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->tone_stream] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [tone_stream] destination_number(+18003713030) =~ /^\*9198$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->hold_music] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [hold_music] destination_number(+18003713030) =~ /^\*9664$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->recordings] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [recordings] destination_number(+18003713030) =~ /^\*(732)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->directory] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [directory] destination_number(+18003713030) =~ /^\*411$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->wake-up] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [wake-up] destination_number(+18003713030) =~ /^\*(925)$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->valet_park] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [valet_park] destination_number(+18003713030) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [valet_park] destination_number(+18003713030) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->operator] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [operator] destination_number(+18003713030) =~ /^0$|^operator$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->operator-forward] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [operator-forward] destination_number(+18003713030) =~ /^\*000$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->do-not-disturb] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [do-not-disturb] destination_number(+18003713030) =~ /^\*77$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [do-not-disturb] destination_number(+18003713030) =~ /^\*78$|\*363$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [do-not-disturb] destination_number(+18003713030) =~ /^\*79$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [do-not-disturb] destination_number(+18003713030) =~ /^dnd\+20$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call_screen] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call_screen] ${call_screen_enabled}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->follow-me-destinations] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [follow-me-destinations] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call-forward] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-forward] destination_number(+18003713030) =~ /^\*72(\d*)$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-forward] destination_number(+18003713030) =~ /^\*73$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-forward] destination_number(+18003713030) =~ /^\*74$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-forward] destination_number(+18003713030) =~ /^forward\+(\Q20\E)(?:\/(\d+))?$/ break=on-true
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call-forward-all] continue=
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-forward-all] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->call-forward-not-registered] continue=
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [call-forward-not-registered] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->follow-me] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [follow-me] destination_number(+18003713030) =~ /^\*21$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->clear_sip_auto_answer] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [clear_sip_auto_answer] ${click_to_call}() =~ /true/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->talking clock date and time] continue=
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [talking clock date and time] destination_number(+18003713030) =~ /^\*9172$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->talking clock time] continue=
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [talking clock time] destination_number(+18003713030) =~ /^\*9170$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->talking clock date] continue=
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [talking clock date] destination_number(+18003713030) =~ /^\*9171$/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->local_extension] continue=true
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [local_extension] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/internal/20@45.34.23.218 parsing [45.34.23.218->voicemail] continue=false
Dialplan: sofia/internal/20@45.34.23.218 Regex (FAIL) [voicemail] ${user_exists}(false) =~ /true/ break=on-false
2020-10-25 04:36:54.323121 [DEBUG] switch_core_state_machine.c:287 (sofia/internal/20@45.34.23.218) State Change CS_ROUTING -> CS_EXECUTE
2020-10-25 04:36:54.323121 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/20@45.34.23.218) State ROUTING going to sleep
2020-10-25 04:36:54.323121 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/20@45.34.23.218) Running State Change CS_EXECUTE (Cur 1 Tot 35191)
2020-10-25 04:36:54.323121 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/20@45.34.23.218) State EXECUTE
2020-10-25 04:36:54.323121 [DEBUG] mod_sofia.c:209 sofia/internal/20@45.34.23.218 SOFIA EXECUTE
2020-10-25 04:36:54.323121 [DEBUG] switch_core_state_machine.c:329 sofia/internal/20@45.34.23.218 Standard EXECUTE
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(caller_id_number=20)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [caller_id_number]=[20]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(RFC2822_DATE=Sun, 25 Oct 2020 04:36:54 -0400)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [RFC2822_DATE]=[Sun, 25 Oct 2020 04:36:54 -0400]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 export(origination_callee_id_name=+18003713030)
2020-10-25 04:36:54.323121 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [origination_callee_id_name]=[+18003713030]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 hash(insert/45.34.23.218-last_dial/20/+18003713030)
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(sip_h_X-accountcode=)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [sip_h_X-accountcode]=[UNDEF]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 export(call_direction=outbound)
2020-10-25 04:36:54.323121 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [call_direction]=[outbound]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 unset(call_timeout)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1817 UNSET [call_timeout]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(hangup_after_bridge=true)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [hangup_after_bridge]=[true]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(effective_caller_id_name=MCT Group)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [effective_caller_id_name]=[MCT Group]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(effective_caller_id_number=+18003713030)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [effective_caller_id_number]=[+18003713030]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(inherit_codec=true)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [inherit_codec]=[true]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(ignore_display_updates=true)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [ignore_display_updates]=[true]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(callee_id_number=18003713030)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [callee_id_number]=[18003713030]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(continue_on_fail=true)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [continue_on_fail]=[true]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(proxy_media=false)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [proxy_media]=[false]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(bypass_media=false)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [bypass_media]=[false]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 set(provider_prefix=021001)
2020-10-25 04:36:54.323121 [DEBUG] mod_dptools.c:1672 SET sofia/internal/20@45.34.23.218 [provider_prefix]=[021001]
EXECUTE [depth=0] sofia/internal/20@45.34.23.218 bridge(sofia/gateway/ebcf1e9f-d639-48ba-927f-5d069bd8d0b8/02100118003713030)
2020-10-25 04:36:54.343080 [DEBUG] switch_channel.c:1264 sofia/internal/20@45.34.23.218 EXPORTING[export_vars] [domain_name]=[45.34.23.218] to event
2020-10-25 04:36:54.343080 [DEBUG] switch_channel.c:1264 sofia/internal/20@45.34.23.218 EXPORTING[export_vars] [call_direction]=[outbound] to event
2020-10-25 04:36:54.343080 [DEBUG] switch_channel.c:1264 sofia/internal/20@45.34.23.218 EXPORTING[export_vars] [origination_callee_id_name]=[+18003713030] to event
2020-10-25 04:36:54.343080 [DEBUG] switch_ivr_originate.c:2242 Parsing global variables
2020-10-25 04:36:54.343080 [NOTICE] switch_channel.c:1118 New Channel sofia/external/02100118003713030 [0adbb20e-a167-4675-84d2-b99c7c1c8a92]
2020-10-25 04:36:54.343080 [DEBUG] mod_sofia.c:5089 (sofia/external/02100118003713030) State Change CS_NEW -> CS_INIT
2020-10-25 04:36:54.343080 [DEBUG] switch_core_state_machine.c:585 (sofia/external/02100118003713030) Running State Change CS_INIT (Cur 2 Tot 35192)
2020-10-25 04:36:54.343080 [DEBUG] switch_core_state_machine.c:628 (sofia/external/02100118003713030) State INIT
2020-10-25 04:36:54.343080 [DEBUG] mod_sofia.c:93 sofia/external/02100118003713030 SOFIA INIT
2020-10-25 04:36:54.343080 [DEBUG] sofia_glue.c:1618 sofia/external/02100118003713030 sending invite version: 1.10.5 -release.8 64bit
Local SDP:
v=0
