Outgoing calls impossible.
OlivierWILLEMS
Hello everyone.
I recently installed Fusion PBX, and all went well.
My trunk is registered.
I've created my inbound and outbound routes.
Incoming calls sound OK
On an outgoing call, I get a temporary unavailable error:
Here are the logs:
When I connect to my firewall, I don't see any exchange between fusionPbx and the trunk.
I think the error is in fusionpbx.
Can you give me some information about the Regex(fail) error in my logs?
Thanks for your help.
Olivier
pbxgeek
146
53
Most regex fails are fine. It's designed to use only ones that pass. Send a pcap of the call so we can see where the issue is. And full FreeSWITCH log, not just a part with regex. Please paste the text. The picture is too blurry to tell what's going on.
pbxgeek
146
53
For freeswitch, you need to provide the log you provided over a screenshot, but it is in text format. Please copy and paste it here and mask any sensitive info. You will find that one call log is a lot longer than what you were able to capture in the screenshot.
For PCAP, run sngrep on your server, and it will generate a sip trace. You can also paste it here.
