SOLVED Language Prompts
Clive Churchyard
16
the included instructions are aimed at Freeswitch but obviously there are some location changes for FusionPBX.
Once the files have been extracted the instructions say this:
5) In order to get your system to use the installed voice prompts instead of
the default language you have to edit a couple of configuration files
so that FreeSWITCH can locate the prompts.
6) Edit /usr/src/freeswitch/conf/freeswitch.xml and add the following line within
the "phrases" section:
<X-PRE-PROCESS cmd="include" data="lang/en/*.xml"/>
Example:
<section name="phrases" description="Speech Phrase Management">
<macros>
<X-PRE-PROCESS cmd="include" data="lang/de/*.xml"/>
<X-PRE-PROCESS cmd="include" data="lang/fr/*.xml"/>
<X-PRE-PROCESS cmd="include" data="lang/it/*.xml"/>
<X-PRE-PROCESS cmd="include" data="lang/hr/*.xml"/>
<X-PRE-PROCESS cmd="include" data="lang/ru/*.xml"/>
</macros>
</section>
however this I think is in /usr/share/freeswitch/vanilla directory and already includes the line in the Language Management section
7) Edit the file /usr/src/freeswitch/modules.conf and add the following line to the "say"
options:
say/mod_say_en
Note: Depending on the FreeSWITCH build and languages installed this might already exist
in the file.
cant find this file - but surely this should be configurable through the GUI
8) Edit the file /usr/local/freeswitch/conf/vars.xml and locate the <!-- Defaults -->
section which currently looks something like this:
<!-- Defaults -->
<X-PRE-PROCESS cmd="set" data="default_language=en"/>
<X-PRE-PROCESS cmd="set" data="default_dialect=us"/>
<X-PRE-PROCESS cmd="set" data="default_voice=callie"/>
Replace the 3 lines under the Defaults header with the following lines:
<X-PRE-PROCESS cmd="set" data="default_dialect=gb"/>
<X-PRE-PROCESS cmd="set" data="default_voice=rachael"/>
Again this should surely be done inthe GUI - but when changed has no effect
9) Build and load the "mod_say_en" language parameter files by logging into the command
shell and running the following commands:
cd /usr/src/freeswitch
./configure
make mod_say_en-install
/usr/local/freeswitch/bin/fs_cli
reload mod_say_en
reload
Is this needed? - if so what are the correct locations and instructions>?
Any help on this would be greatly appreciated
Clive
Duncan
Hi Clive.
What method did you use to install Fusionpbx. I am looking at mine and none of the locations match up (presumably because I did a package install on Debian).
Clive Churchyard
16
I have used both the debian packaged install as in the quick start guide and also the cluster install script.
none of the westany locations match i agree
Some on must have done this with success!
Clive Churchyard
16
the only way i can see to make it work is to rename the uploaded folders 'gb' and 'rachael' to 'us' and 'callie'
Which is fine, but not ideal, if only a single language is required
Jonathan R.
14
Anyone has update for this ? Renaming works, but i live in Québec, we need to have bilingual systems.
i tried changing values in Variables (the 4 values) but it says "Identification incorrecte" (EN : Incorrect ID) repeatedly when i dial *97 and *732 just hang up.
I chown files to www-data:www-data and 755 but still won't work.
Frank
61
I live in Quebec and the way I have it working is by setting a default language for Fusion. Then I set the individual domains to either English or French by changing the settings in Dial Plan Manager 'Variables'. I also have some domains set to bilingual when using IVR's (It was a little tricky setting this up so I paid someone to set this up and it works like a charm).
Frank
61
If your logs are showing this..
2018-05-10 15:14:50.662649 [ERR] mod_local_stream.c:467 Can't open Attente_Musicale.wav
2018-05-10 15:14:50.682616 [ERR] mod_sndfile.c:204 Error Opening File [Attente_Musicale.wav] [System error : No such file or directory.]
2018-05-10 15:14:50.682616 [ERR] mod_local_stream.c:467 Can't open Attente_Musicale.wav
2018-05-10 15:14:50.702616 [ERR] mod_sndfile.c:204 Error Opening File [Attente_Musicale.wav] [System error : No such file or directory.]
Then its another issue..
JamesBorne
294
57
Australia
Got this to work fine last night using Westany. Changed from en-us Callie to en-au Madison.
I changed four variables in Advanced > Variables:
default_voice
default_language (well, mine was en and stayed en)
default_dialect
sound_prefix
Then I went to Advanced > XML Editor and changed the languages/en/en.xml file header from:
<language name="en" say-module="en" sound-prefix="$${sounds_dir}/en/us/callie" tts-engine="cepstral" tts-voice="callie">
to:
<language name="en" say-module="en" sound-prefix="$${sounds_dir}/en/au/madison" tts-engine="cepstral" tts-voice="madison">
Lastly, I went to Status > SIP Status and hit Flush Cache and Reload XML
Done.
