SOLVED Ip Authentication Trunk/Gatwey Settings
I had the same issue... Changing to port 5080 really helped solved the issue. Thanks a Ton!
they are in the ACL list
i am still getting
2017-10-29 03:40:19.794087 [WARNING] sofia_reg.c:2906 Can't find user [pt@45.77.106.23] from 64.2.142.90
You must define a domain called '45.77.106.23' in your directory and add a user with the id="pt" attribute
64.2.142.90 is in the ACL and 45.77.106.23 is the domain and pt is the user??
Also, you shouldn't be using server IP anyway, everything in fusionpbx is domain based.
@DigitalDaz thanks for your help,
i am using IP since my provider will only send calls to IP and not Domain
i am not sure who is PT this is a IP based Auth.
it worked Fine with my asterisk BOX with the same provider
i can reach out to .vitelity to check why they are sending that "PT"
also will see if they will send it to a domain, in the control panel they will only send it to an IP no domain allowed
The real key here though is whether that IP 64.2.142.90 is in the domain acl
Can you show a screen shot of the domain ACL please? Also remember, it must be in CIDR format eg 64.2.142.90/32
Firstly, the default for the domains should be 'DENY'
But then the allow for the CIDR should be there but with nothing in the Domain field, ie empty
this was my original settings but i did allow and add it domain to test if it will work,,
anyway i changed it back still the same error in the log files about user PT and domain
You may now have to do a reloadacl at the command line, you should see it in the list as it reloads
