Integrate billing for fusionpbx
dgxa
38
Lima, Peru
Hello I want to add modules to integrate the billing function to fusionpbx. At the moment the modules that I contemplate are these:
mod_nibblebill
mod_lcr
mod_easyroute
For other part how option 2 I can integrate Cgrates with fusionpbx. I read that the only module that i nedd is mod_json_cdr
I want to know if someone has experience with this, since i want to know what is the better option to use.
geomat
www.linkedin.com
If you want to go with a commercial solution you can also try Kolmisoft MOR. I am using it for the last couple of years and everything is working well.
Reactions: dgxa
