FusionPBX Routing outbound calls to user extension
teditn
17
thank you for your answer my problem that I have a gateway linksys spa-2000 it is configure as user in fusionpbx under number 999 I want when I call for example the number gsm 22100200 will be transmitted to number 999 because it is connected to pstn in linksys spa-200
you can see the pictures attached
teditn
17
Can you see this registered properly in - STATUS - REGISTRATIONS
Is account 999 showing in there online?
in gateway menu no but in status -registrations yes and when I call from outside it works call it transfer to number 100
