FusionPBX outgoing call failed
I have told you that they are on the wrong port and profile, I could not care less whether it sometimes works or not. I'll be answering no more questions on this thread. If you cannot listen, I cannot teach.
haha, bye since this post =))
Last update: Finally I found the solution for my situation, it's relate to sip alg, after disable sip alg on firewall then outgoing call works as well.
It's not relate to port/ profile, I kept using external profile for both gateway and extensions with port 5080.
