enable the record for outgoing and incoming calls
579
I have just made a brand new install here and call recording works just fine, you must have altered something as this literally is fresh out of the box. I have done no more than create a couple of extensions and a destination:
The first call shown is a simulated inbound call to a DID 11111 and the second call is just a regular extension to extension call.
ppenkov
Thank you for the feedback.
I have to do some other tests, after which I'll do a new install.
Anyway, at least now I know where I have to look.
mc6650
112
Hello
Quick question. Can the call record feature be set up to be "on demand". For example if extension 203 is a Yealink cordless phone could I setup a feature code (*1) so that if I chose to record a call I would press *1 while on the call. To retrieve the recording I would log into my user profile for 203 and listen to it from there. Thanks in advance for any help that can be provided.
