customise random password generated for ivr recording using *732
karthiksg
Dial *732 to create a recording, or (for best results) upload a 16bit 8khz/16khz mono WAV file.
To view and set the pin number goto Dialplan > Dialplan Manager > Click on Recordings > pin_number=8675309 at the bottom
I need to know how and where to change this "pin_number=8675309" digits generation from 7 digits to 3 digit random number or can i assign any 3 digit static pin number for all accounts (global)
karthiksg
i found the existing data is in v_dialplan_data table > dialplan_detail_data column but not sure where its generated and inserted from
i may need to know in which file /var/www/fusionpbx/app/dialplan/dialplans.php or dialplan_edit.php or when i create domain is it generated from there /var/www/fusionpbx/core/domains need help
anyone pls adviice
voipBull
66
11
In 'Dialplan Manager', look for 'recordings' (Number *732, Order 400). In there is an action to set the pin_number value.
karthiksg
yes i know this, i want an option to change the default value digits to reduce. currently its showing 8 digits, i want to have random 4 digits or static 1234 as for all users
