Connection to Event Socket failed.
583
I've just been banned from the fusionpbx irc channel for the views I expressed in here earlier so I'm starting #fusionpbxforums, pop in there if you need anything you can't get dealt with in #fusionpbx.
Andrew Byrd
309
What is the proper way for me to add OPENCNAM as the cnam lookup for incoming caller ID? Is there a better way or service than that one? I am open to suggestions I just want reliable caller ID info. Voip innovations provides it also from the origination side as well, but if I can provide it at server level I would rather.
583
I am from UK so you would be better with an answer from the USA guys, start a new thread for it maybe, ask what they are using.
583
I don't mind, I will build a mattermost chat server now for the forums to go with the shiny new look :)
