Advice on SMS gateway...
Earlier this year, we got inbound working with Telnyx on 5.2 with Messages, and Groundwire App. Then, it all mysteriously stopped working and I do believe Telnyx JSON method changed.
In any case, we learned that to deliver to an extension, you need the following: +1 DID >> Extension >>User >> Contact - The key was the contact record where you enabled Text and make sure the +1 DID is set. This is how we can inbound finally working..then it broke. You guys are inspiring me to try again.
Hi there,
Thanks for the information, with this I was able to adjust some things.
On my Fusionpbx 5.3, and Telnyx, I am receiving incoming SMS, but the message is arriving to all extensions at the same time, and only the Zopier app is able to receive it.
Gloundwire received the SMS only once, and no more.
If you could share some more prints of your inbounds for the SMS, I would be grateful.
I'm also starting testing with Twilio, if anyone has anything to share.
Thank you
