Kamailio/FusionPBX and Microsoft Direct Routing Integration
377
i try not use opensips just because they "Stole" their project from kamailio so for me its a moral issue, but not saying its bad, i just saw what they did to daniel
How did this bit of history pass me by?? I started out with OpenSer (Sip Express Router) , I assumed OpenSIPS was the natural progression from that. Not going to hijack this tread, but if you have the time to tell me more send me a PM. Cheers,
Adrian.
566
Adrian, that custom on reply route worked a treat!!!!!!!!!!!!!!!!!!!!!!!!!!
        if (t_check_status("183|180|200") && has_body("application/sdp")) {
                if(search_body("a=sendrecv")) {
                        subst_body('/^a=sendrecv/a=inactive/');
                        msg_apply_changes();
                route(RTPENGINEANSWER);
Now that is teams going via my kamailio to an ASTPP instance :)
Reactions: Adrian Fretwell
andycol
47
14
Awesome, would you mind to share you kamailio config?
566
No, he isn't selling them, that code apparently is still private and not released yet according to the group.
566
oh when i spoke to him he said to use direct routing support on dsiprouter you need to purchase a license
Look on the google group, I asked him, you can buy it now but you only get whats currently in which is a partially working thing, when I looked at the code I could see there was no way of handling certain things, thats when I asked him and he said the things that don't work will be in the next version which is a private repo but thats not ready yet.
bcmike
327
55
A couple of days ago, I was gonna buy a piece:View attachment 1627
I have no Kamailio game whatsoever so I bought a small piece. I just wanted to get in and out working, but yes hold and transfer are still issues. Honestly I feel like a bit of a beta tester but Mack makes weekly progress and the support has been really good so I can't complain.
566
I think he needs to introduce a B2BUA, Carriers are so much differing in their support for REPLACE, the way they do HOLD/UNHOLD etc.
ewdpb
151
19
With all the respect and in my humble opinion, if you guys add the amount of hours invested trying to hack your way down through this configuration, paying for AnyNode or Audiocodes alternatives may actually be less expensive.
566
I already have a fully working, as far as I can tell, solution with Kamailio and Freeswitch that should work as well as their cloud offerings. I have hold, transfer, blind transfer etc.
bcmike
327
55
You might be right, but there's a learning curve with those products as well, IMHO I might as well invest that time with something open and support people working with open source products. I may however still be barking up the wrong tree as I don't think Mack is as far along as Daz.
Reactions: krooney
gflow
262
Great work, is that using the config you shared or is there an updated version?
ScITGmbH
And, multitenant of course.
@DigitalDaz Do you mind to share your kamailio config once again? I got the connection between Teams <-> Kamailio working, now struggeling (hard) with the call handling for Kamailio <-> FusionPBX. Also your adaption for multitentant would be very interresting.
I also would take any notes to bring me forward, would offer to do a clean writeup after I got it working :).
Reactions: robvandenbulk
