Follow Me Confirm Prompts
chind
Does anyone know where I could change the audio file for the prompt when a "Follow Me" call in answered? And if you do know, can I change it on a domain by domain basis?
Thanks.
377
It's a long while since I looked at Fusion, but I'm pretty sure it is hard coded into the code that creates the statement to bridge all the destinations.
It's a channel variable called group_confirm_file that is normally set to "ivr/ivr-accept_reject.wav"
This may have changed in the later versions?
hamagid
73
It's set in /usr/share/freeswitch/scripts/confirm.lua
You can set it there to another audio file, or you can set it to a variable that you'll be able to set to a different audio file per domain.
