Duplicate Domains menu after upgrade from 5.1.3 to 5.1.4
voipBull
42
Completed an upgrade from 5.1.3 to 5.1.4 today, but following the upgrade 'Domains' menu is duplicated (screenshot attached) showing the same things when either one of them is clicked on. Tried looking into default menu manager and dashboard.php / domains.php but couldn't really make sense why its happening. Any clues?
markjcrane
453
162
Is the user assigned to 2 groups that both have access to the same item in the menu? Also make sure the superadmin group is not assigned twice to the Domains menu item. You can find it here at Advanced -> Menu Manager -> default.
Reactions: vuthy09
voipBull
42
@markjcrane Web user that I'm logging in as is part of only the 'superadmin' group. Yes, I noticed that too at first that under Advanced > Menu manager > default, superadmin group was assigned twice to the Domians menu item but even after removing one of them, and reloading > logout > login, shows the same duplicate Domains menu.
