DNC - Do Not Call List
Win
Good day everyone,
Call Block supposed to work on both In and Outbound calls, why? because there is 2 direction options (In/Outbound).
I set 0817145779 in the Call Block with Outbound direction, I expect none would be able to call that number.
What I have done:
- Call Block
Direction: Outbound
Extension: All
Number: Empty
Action: Reject
And based on this: https://docs.fusionpbx.com/en/latest/applications/call_block.html
I have to add a new call-direction in Outbound route:
Order: 030
Continue: True
Enabled: True
Tag: condition
Type: destination_number
Data: ^(?:\+?62|0)(\d+)$
Enabled: True
Tag: action
Type: export
Data: call_direction=outbound
Enabled: True
I also have restarted the freeswitch to make sure.
but why I (101) still able to call that number? any body had experienced on this?
=== freeswitch.log ===
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.437991 99.80% [NOTICE] switch_channel.c:1142 New Channel sofia/internal/101@pbx.example.co.id [01decfd8-7b25-4d93-af4c-82bba64797c7]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.437991 99.80% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/101@pbx.example.co.id) Running State Change CS_NEW (Cur 1 Tot 1)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.437991 99.80% [INFO] sofia.c:10459 sofia/internal/101@pbx.example.co.id receiving invite from 175.158.58.169:58128 version: 1.10.11 -release 64bit call-id: b2c02f03ba5e4021bd0775e993cdbe65
2024-02-21 07:50:23.437991 99.80% [DEBUG] sofia.c:10553 verifying acl "providers" for ip/port 175.158.58.169:0.
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.437991 99.80% [DEBUG] switch_core_state_machine.c:600 (sofia/internal/101@pbx.example.co.id) State NEW
2024-02-21 07:50:23.437991 99.80% [DEBUG] sofia.c:2419 detaching session 01decfd8-7b25-4d93-af4c-82bba64797c7
2024-02-21 07:50:23.457990 99.80% [DEBUG] sofia.c:2532 Re-attaching to session 01decfd8-7b25-4d93-af4c-82bba64797c7
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.457990 99.80% [INFO] sofia.c:10459 sofia/internal/101@pbx.example.co.id receiving invite from 175.158.58.169:58128 version: 1.10.11 -release 64bit call-id: b2c02f03ba5e4021bd0775e993cdbe65
2024-02-21 07:50:23.457990 99.80% [DEBUG] sofia.c:10553 verifying acl "providers" for ip/port 175.158.58.169:0.`
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] sofia.c:7493 Channel sofia/internal/101@pbx.example.co.id entering state [received][100]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] sofia.c:7503 Remote SDP:
01decfd8-7b25-4d93-af4c-82bba64797c7 v=0
01decfd8-7b25-4d93-af4c-82bba64797c7 o=- 3917490623 3917490623 IN IP4 175.158.58.169
01decfd8-7b25-4d93-af4c-82bba64797c7 s=pjmedia
01decfd8-7b25-4d93-af4c-82bba64797c7 b=AS:84
01decfd8-7b25-4d93-af4c-82bba64797c7 t=0 0
01decfd8-7b25-4d93-af4c-82bba64797c7 a=X-nat:0
01decfd8-7b25-4d93-af4c-82bba64797c7 m=audio 4004 RTP/AVP 8 0 101
01decfd8-7b25-4d93-af4c-82bba64797c7 c=IN IP4 175.158.58.169
01decfd8-7b25-4d93-af4c-82bba64797c7 b=TIAS:64000
01decfd8-7b25-4d93-af4c-82bba64797c7 a=rtpmap:8 PCMA/8000
01decfd8-7b25-4d93-af4c-82bba64797c7 a=rtpmap:0 PCMU/8000
01decfd8-7b25-4d93-af4c-82bba64797c7 a=rtpmap:101 telephone-event/8000
01decfd8-7b25-4d93-af4c-82bba64797c7 a=fmtp:101 0-16
01decfd8-7b25-4d93-af4c-82bba64797c7 a=rtcp:4005 IN IP4 192.168.1.13
01decfd8-7b25-4d93-af4c-82bba64797c7 a=ssrc:1365846142 cname:57cb4bd17f2d6c3f
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] sofia.c:7906 (sofia/internal/101@pbx.example.co.id) State Change CS_NEW -> CS_INIT
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/101@pbx.example.co.id) Running State Change CS_INIT (Cur 1 Tot 1)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:624 (sofia/internal/101@pbx.example.co.id) State INIT
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_sofia.c:97 sofia/internal/101@pbx.example.co.id SOFIA INIT
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:40 sofia/internal/101@pbx.example.co.id Standard INIT
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:48 (sofia/internal/101@pbx.example.co.id) State Change CS_INIT -> CS_ROUTING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:624 (sofia/internal/101@pbx.example.co.id) State INIT going to sleep
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/101@pbx.example.co.id) Running State Change CS_ROUTING (Cur 1 Tot 1)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_channel.c:2399 (sofia/internal/101@pbx.example.co.id) Callstate Change DOWN -> RINGING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:640 (sofia/internal/101@pbx.example.co.id) State ROUTING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_sofia.c:158 sofia/internal/101@pbx.example.co.id SOFIA ROUTING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:230 sofia/internal/101@pbx.example.co.id Standard ROUTING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [INFO] mod_dialplan_xml.c:639 Processing 101 <101>->0817145779 in context pbx.example.co.id
2024-02-21 07:50:23.477998 99.80% [NOTICE] switch_cpp.cpp:1466 [xml_handler] multiple key:dialplan:pbx.example.co.id
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->inter-domains] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [inter-domains] ${user_exists}() =~ /false/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->user_exists] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_exists] ${loopback_leg}() =~ /^B$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [user_exists] () =~ // break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(user_exists=false)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [user_exists]=[false]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(from_user_exists=${user_exists id ${sip_from_user} ${sip_from_host}}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(from_user_exists=true)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [from_user_exists]=[true]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->caller-details] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [caller-details] ${caller_destination}() =~ /^$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(caller_destination=${destination_number}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(caller_destination=0817145779)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [caller_destination]=[0817145779]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(caller_id_name=${caller_id_name}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(caller_id_name=101)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [caller_id_name]=[101]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(caller_id_number=${caller_id_number})
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->global-variables] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [global-variables] () =~ // break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->domain-variables] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [domain-variables] () =~ // break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action export(origination_callee_id_name=${caller_destination})
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(operator=1000) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(operator=1000)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [operator]=[1000]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call_direction-outbound] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [call_direction-outbound] ${user_exists}(false) =~ /false/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [call_direction-outbound] ${call_direction}() =~ /^$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [call_direction-outbound] destination_number(0817145779) =~ /^(?:\+?62|0)(\d+)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(callee_id_number=0817145779)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action export(call_direction=outbound) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id export(call_direction=outbound)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_channel.c:1334 EXPORT (export_vars) [call_direction]=[outbound]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->clear_sip_auto_answer] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [clear_sip_auto_answer] ${click_to_call}() =~ /true/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->is_loopback] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [is_loopback] ${is_follow_me_loopback}() =~ /true/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call-direction] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-direction] ${call_direction}(outbound) =~ /^$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call_block] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [call_block] ${call_direction}(outbound) =~ /^(inbound|outbound)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action lua(app.lua call_block)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->user_record] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${call_direction}(outbound) =~ /^inbound$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [user_record] ${call_direction}(outbound) =~ /^outbound$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${call_direction}(outbound) =~ /^local$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [user_record] ${from_user_exists}(true) =~ /^true$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(from_user_record=${user_data ${sip_from_user}@${sip_from_host} var user_record}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(from_user_record=)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [from_user_record]=[UNDEF]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->rtp_has_crypto] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [rtp_has_crypto] ${rtp_has_crypto}() =~ /^(AEAD_AES_256_GCM_8|AEAD_AES_128_GCM_8|AES_CM_256_HMAC_SHA1_80|AES_CM_192_HMAC_SHA1_80|AES_CM_128_HMAC_SHA1_80|AES_CM_256_HMAC_SHA1_32|AES_CM_192_HMAC_SHA1_32|AES_CM_128_HMAC_SHA1_32|AES_CM_128_NULL_AUTH)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->redial] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [redial] destination_number(0817145779) =~ /^(redial|\*870)$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [redial] () =~ // break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->speed_dial] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [speed_dial] destination_number(0817145779) =~ /^\*0(.*)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->user_hold_music] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [user_hold_music] ${user_exists}(false) =~ /true/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->default_caller_id] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [default_caller_id] ${call_direction}(outbound) =~ /outbound/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [default_caller_id] ${emergency_caller_id_name}() =~ /^$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(emergency_caller_id_name=)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [emergency_caller_id_name]=[UNDEF]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(emergency_caller_id_number=)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [emergency_caller_id_number]=[UNDEF]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [default_caller_id] ${loopback_leg}() =~ /^$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [default_caller_id] ${outbound_caller_id_name}() =~ /^$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(outbound_caller_id_name=)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [outbound_caller_id_name]=[UNDEF]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(outbound_caller_id_number=)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [outbound_caller_id_number]=[UNDEF]
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->622131180035-Out] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [622131180035-Out] ${user_exists}(false) =~ /false/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (PASS) [622131180035-Out] destination_number(0817145779) =~ /^(?:\+?62|0)(\d+)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action unset(call_timeout)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(hangup_after_bridge=true)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(effective_caller_id_name=${outbound_caller_id_name})
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(effective_caller_id_number=${outbound_caller_id_number})
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(inherit_codec=true)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(ignore_display_updates=true)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action set(continue_on_fail=1,2,3,6,18,21,27,28,31,34,38,41,42,44,58,88,111,403,501,602,607,809)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Action bridge(sofia/gateway/ad676e11-b979-48bc-b88f-de56da4a0a0e/0817145779)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->RG-01] continue=
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [RG-01] destination_number(0817145779) =~ /^2$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->IVR 01] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [IVR 01] destination_number(0817145779) =~ /^1$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->agent_status] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [agent_status] destination_number(0817145779) =~ /^\*22$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [agent_status] destination_number(0817145779) =~ /^(?:agent\+|\*22)(.+)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->agent_status_id] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [agent_status_id] destination_number(0817145779) =~ /^\*23$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->agent-status-break] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [agent-status-break] destination_number(0817145779) =~ /^\*24$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [agent-status-break] destination_number(0817145779) =~ /^(?:agent\+|\*24)(.+)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->group-intercept] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [group-intercept] destination_number(0817145779) =~ /^\*8$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->page-extension] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [page-extension] destination_number(0817145779) =~ /^\*8(\d{2,7})$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->eavesdrop] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [eavesdrop] destination_number(0817145779) =~ /^\*33(\d{2,7})$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call_privacy] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call_privacy] destination_number(0817145779) =~ /^\*67(\d+)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call_return] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call_return] destination_number(0817145779) =~ /^\*69$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->intercept-ext-polycom] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [intercept-ext-polycom] destination_number(0817145779) =~ /^\*97(\d+)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->number_queue] continue=
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [number_queue] destination_number(0817145779) =~ /^\*800(.*)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->intercept-ext] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [intercept-ext] destination_number(0817145779) =~ /^\*\*(\d+)$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [intercept-ext] destination_number(0817145779) =~ /^\*\*$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->dx] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [dx] destination_number(0817145779) =~ /^dx$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->send_to_voicemail] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [send_to_voicemail] destination_number(0817145779) =~ /^\*99(\d{2,10})$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->extension-to-voicemail] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->att_xfer] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [att_xfer] destination_number(0817145779) =~ /^att_xfer$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->xfer_vm] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [xfer_vm] destination_number(0817145779) =~ /^xfer_vm$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->vmain] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [vmain] destination_number(0817145779) =~ /^vmain$|^\*4000$|^\*98$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [vmain] destination_number(0817145779) =~ /^(vmain$|^\*4000$|^\*98|voicemail\+)(\d{2,12})$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->is_transfer] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [is_transfer] destination_number(0817145779) =~ /^is_transfer$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->vmain_user] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [vmain_user] destination_number(0817145779) =~ /^\*97$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->delay_echo] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [delay_echo] destination_number(0817145779) =~ /^\*9195$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->cf] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [cf] destination_number(0817145779) =~ /^cf$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->echo] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [echo] destination_number(0817145779) =~ /^\*9196$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->is_zrtp_secure] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id ANTI-Action eval(not_secure)
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->milliwatt] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [milliwatt] destination_number(0817145779) =~ /^\*9197$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->tone_stream] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [tone_stream] destination_number(0817145779) =~ /^\*9198$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->is_secure] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->hold_music] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [hold_music] destination_number(0817145779) =~ /^\*9664$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->recordings] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [recordings] destination_number(0817145779) =~ /^\*(732)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->directory] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [directory] destination_number(0817145779) =~ /^\*411$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->wake-up] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [wake-up] destination_number(0817145779) =~ /^\*(925)$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->valet_park] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [valet_park] destination_number(0817145779) =~ /^(park)?\+?\*(59[0-9][0-9])$/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [valet_park] destination_number(0817145779) =~ /^(park)?\+?\*(59[0-9][0-9])$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->operator-forward] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [operator-forward] destination_number(0817145779) =~ /^\*000$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->do-not-disturb] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [do-not-disturb] destination_number(0817145779) =~ /^\*77$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [do-not-disturb] destination_number(0817145779) =~ /^\*78$|\*363$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [do-not-disturb] destination_number(0817145779) =~ /^\*79$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [do-not-disturb] destination_number(0817145779) =~ /^dnd\+101$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call_screen] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call_screen] ${call_screen_enabled}(false) =~ /^true$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->ring-group-forward] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [ring-group-forward] destination_number(0817145779) =~ /^\*75$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call-forward] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-forward] destination_number(0817145779) =~ /^\*72(\d{2,20})$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-forward] destination_number(0817145779) =~ /^\*72$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-forward] destination_number(0817145779) =~ /^\*73$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-forward] destination_number(0817145779) =~ /^\*74$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-forward] destination_number(0817145779) =~ /^forward\+(\Q101\E)(?:\/(\d+))?$/ break=on-true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call-forward-not-registered] continue=
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-forward-not-registered] ${user_exists}(false) =~ /true/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->follow-me] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [follow-me] destination_number(0817145779) =~ /^\*21$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->call-forward-all] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [call-forward-all] ${forward_all_enabled}() =~ /true/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->follow-me-destinations] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [follow-me-destinations] ${user_exists}(false) =~ /^true$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->talking clock date and time] continue=
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [talking clock date and time] destination_number(0817145779) =~ /^\*9172$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->talking clock time] continue=
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [talking clock time] destination_number(0817145779) =~ /^\*9170$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->talking clock date] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [talking clock date] destination_number(0817145779) =~ /^\*9171$/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->local_extension] continue=true
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [local_extension] ${user_exists}(false) =~ /true/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id parsing [pbx.example.co.id->voicemail] continue=false
01decfd8-7b25-4d93-af4c-82bba64797c7 Dialplan: sofia/internal/101@pbx.example.co.id Regex (FAIL) [voicemail] ${user_exists}(false) =~ /true/ break=on-false
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:281 (sofia/internal/101@pbx.example.co.id) State Change CS_ROUTING -> CS_EXECUTE
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:640 (sofia/internal/101@pbx.example.co.id) State ROUTING going to sleep
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/101@pbx.example.co.id) Running State Change CS_EXECUTE (Cur 1 Tot 1)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:647 (sofia/internal/101@pbx.example.co.id) State EXECUTE
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_sofia.c:213 sofia/internal/101@pbx.example.co.id SOFIA EXECUTE
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:323 sofia/internal/101@pbx.example.co.id Standard EXECUTE
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(caller_id_number=101)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [caller_id_number]=[101]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(RFC2822_DATE=Wed, 21 Feb 2024 07:50:23 +0700)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [RFC2822_DATE]=[Wed, 21 Feb 2024 07:50:23 +0700]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id export(origination_callee_id_name=0817145779)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_channel.c:1334 EXPORT (export_vars) [origination_callee_id_name]=[0817145779]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(callee_id_number=0817145779)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [callee_id_number]=[0817145779]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id lua(app.lua call_block)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_cpp.cpp:1210 sofia/internal/101@pbx.example.co.id destroy/unlink session from object
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id hash(insert/pbx.example.co.id-last_dial/101/0817145779)
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id unset(call_timeout)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1816 UNSET [call_timeout]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(hangup_after_bridge=true)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [hangup_after_bridge]=[true]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(effective_caller_id_name=)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [effective_caller_id_name]=[UNDEF]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(effective_caller_id_number=)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [effective_caller_id_number]=[UNDEF]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(inherit_codec=true)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [inherit_codec]=[true]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(ignore_display_updates=true)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [ignore_display_updates]=[true]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id set(continue_on_fail=1,2,3,6,18,21,27,28,31,34,38,41,42,44,58,88,111,403,501,602,607,809)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_dptools.c:1671 SET sofia/internal/101@pbx.example.co.id [continue_on_fail]=[1,2,3,6,18,21,27,28,31,34,38,41,42,44,58,88,111,403,501,602,607,809]
01decfd8-7b25-4d93-af4c-82bba64797c7 EXECUTE [depth=0] sofia/internal/101@pbx.example.co.id bridge(sofia/gateway/ad676e11-b979-48bc-b88f-de56da4a0a0e/0817145779)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_channel.c:1288 sofia/internal/101@pbx.example.co.id EXPORTING[export_vars] [domain_name]=[pbx.example.co.id] to event
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_channel.c:1288 sofia/internal/101@pbx.example.co.id EXPORTING[export_vars] [domain_uuid]=[77527d50-4d75-4756-9b39-f4298ffc455c] to event
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_channel.c:1288 sofia/internal/101@pbx.example.co.id EXPORTING[export_vars] [call_direction]=[outbound] to event
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_channel.c:1288 sofia/internal/101@pbx.example.co.id EXPORTING[export_vars] [origination_callee_id_name]=[0817145779] to event
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_ivr_originate.c:2301 Parsing global variables
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [NOTICE] switch_channel.c:1142 New Channel sofia/external/0817145779 [efbe0fc4-54b1-4f4e-b66a-b36845d8d970]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_sofia.c:5110 (sofia/external/0817145779) State Change CS_NEW -> CS_INIT
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:581 (sofia/external/0817145779) Running State Change CS_INIT (Cur 2 Tot 2)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:624 (sofia/external/0817145779) State INIT
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_sofia.c:97 sofia/external/0817145779 SOFIA INIT
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [INFO] sofia_glue.c:1659 sofia/external/0817145779 sending invite call-id: (null)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] sofia_glue.c:1662 sofia/external/0817145779 sending invite version: 1.10.11 -release 64bit
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 Local SDP:
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 v=0
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 o=FreeSWITCH 1708447669 1708447670 IN IP4 149.129.248.234
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 s=FreeSWITCH
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 c=IN IP4 149.129.248.234
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 t=0 0
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 m=audio 28954 RTP/AVP 8 0 101
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 a=rtpmap:8 PCMA/8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 a=rtpmap:0 PCMU/8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 a=rtpmap:101 telephone-event/8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 a=fmtp:101 0-15
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 a=silenceSupp:eek:ff - - - -
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 a=ptime:20
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 a=sendrecv
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:40 sofia/external/0817145779 Standard INIT
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:48 (sofia/external/0817145779) State Change CS_INIT -> CS_ROUTING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:624 (sofia/external/0817145779) State INIT going to sleep
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:581 (sofia/external/0817145779) Running State Change CS_ROUTING (Cur 2 Tot 2)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] switch_core_state_machine.c:640 (sofia/external/0817145779) State ROUTING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.477998 99.80% [DEBUG] mod_sofia.c:158 sofia/external/0817145779 SOFIA ROUTING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.497997 99.80% [DEBUG] switch_ivr_originate.c:67 (sofia/external/0817145779) State Change CS_ROUTING -> CS_CONSUME_MEDIA
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.497997 99.80% [DEBUG] switch_core_state_machine.c:640 (sofia/external/0817145779) State ROUTING going to sleep
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.497997 99.80% [DEBUG] switch_core_state_machine.c:581 (sofia/external/0817145779) Running State Change CS_CONSUME_MEDIA (Cur 2 Tot 2)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.497997 99.80% [DEBUG] switch_core_state_machine.c:659 (sofia/external/0817145779) State CONSUME_MEDIA
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.497997 99.80% [DEBUG] switch_core_state_machine.c:659 (sofia/external/0817145779) State CONSUME_MEDIA going to sleep
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:23.497997 99.80% [DEBUG] sofia.c:7493 Channel sofia/external/0817145779 entering state [calling][0]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] sofia.c:7493 Channel sofia/external/0817145779 entering state [proceeding][183]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] sofia.c:7503 Remote SDP:
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 o=GANG 749391040 749391041 IN IP4 43.245.185.3
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 s=-
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 c=IN IP4 43.245.185.3
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 m=audio 10076 RTP/AVP 8 101
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [NOTICE] sofia.c:7506 Pre-Answer sofia/external/0817145779!
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_channel.c:3585 (sofia/external/0817145779) Callstate Change DOWN -> EARLY
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:5588 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:5438 Set telephone-event payload to 101@8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:3731 Set Codec sofia/external/0817145779 PCMA/8000 20 ms 160 samples 64000 bits 1 channels
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_codec.c:111 sofia/external/0817145779 Original read codec set to PCMA:8
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:5798 Set telephone-event payload to 101@8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:5856 sofia/external/0817145779 Set 2833 dtmf send payload to 101 recv payload to 101
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:8660 AUDIO RTP [sofia/external/0817145779] 172.31.203.210 port 28954 -> 43.245.185.3 port 10076 codec: 8 ms: 20
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_rtp.c:4563 Starting timer [soft] 160 bytes per 20ms
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:8973 sofia/external/0817145779 Set 2833 dtmf send payload to 101
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:8980 sofia/external/0817145779 Set 2833 dtmf receive payload to 101
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.257997 99.73% [DEBUG] switch_core_media.c:9003 sofia/external/0817145779 Set rtp dtmf delay to 40
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_ivr_originate.c:455 Setting codec string on sofia/internal/101@pbx.example.co.id to PCMA@8000h@20i
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [INFO] switch_ivr_originate.c:3862 Sending early media
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:5588 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:5438 Set telephone-event payload to 101@8000
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:3731 Set Codec sofia/internal/101@pbx.example.co.id PCMA/8000 20 ms 160 samples 64000 bits 1 channels
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_codec.c:111 sofia/internal/101@pbx.example.co.id Original read codec set to PCMA:8
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:5798 Set telephone-event payload to 101@8000
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:5856 sofia/internal/101@pbx.example.co.id Set 2833 dtmf send payload to 101 recv payload to 101
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:8660 AUDIO RTP [sofia/internal/101@pbx.example.co.id] 172.31.203.210 port 26468 -> 175.158.58.169 port 4004 codec: 8 ms: 20
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_rtp.c:4563 Starting timer [soft] 160 bytes per 20ms
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_core_media.c:8881 Activating RTCP PORT 4005
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.277992 99.73% [DEBUG] switch_rtp.c:4895 RTCP send rate is: 1000 and packet rate is: 20000 Remote Port: 4005
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_rtp.c:2689 Setting RTCP remote addr to 175.158.58.169:4005 2
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_core_media.c:8973 sofia/internal/101@pbx.example.co.id Set 2833 dtmf send payload to 101
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_core_media.c:8980 sofia/internal/101@pbx.example.co.id Set 2833 dtmf receive payload to 101
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_core_media.c:9003 sofia/internal/101@pbx.example.co.id Set rtp dtmf delay to 40
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [NOTICE] sofia_media.c:90 Pre-Answer sofia/internal/101@pbx.example.co.id!
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_channel.c:3585 (sofia/internal/101@pbx.example.co.id) Callstate Change RINGING -> EARLY
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_core_media.c:8642 Audio params are unchanged for sofia/internal/101@pbx.example.co.id.
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] mod_sofia.c:2607 Ring SDP:
01decfd8-7b25-4d93-af4c-82bba64797c7 o=FreeSWITCH 1708450156 1708450157 IN IP4 149.129.248.234
01decfd8-7b25-4d93-af4c-82bba64797c7 s=FreeSWITCH
01decfd8-7b25-4d93-af4c-82bba64797c7 c=IN IP4 149.129.248.234
01decfd8-7b25-4d93-af4c-82bba64797c7 m=audio 26468 RTP/AVP 8 101
01decfd8-7b25-4d93-af4c-82bba64797c7 a=fmtp:101 0-15
01decfd8-7b25-4d93-af4c-82bba64797c7 a=ptime:20
01decfd8-7b25-4d93-af4c-82bba64797c7 a=sendrecv
01decfd8-7b25-4d93-af4c-82bba64797c7 a=rtcp:26469 IN IP4 149.129.248.234
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_ivr_originate.c:3913 Originate Resulted in Success: [sofia/external/0817145779] Peer UUID: efbe0fc4-54b1-4f4e-b66a-b36845d8d970
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.297999 99.73% [DEBUG] sofia.c:7493 Channel sofia/internal/101@pbx.example.co.id entering state [early][183]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_ivr_bridge.c:1791 (sofia/external/0817145779) State Change CS_CONSUME_MEDIA -> CS_EXCHANGE_MEDIA
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_core_state_machine.c:581 (sofia/external/0817145779) Running State Change CS_EXCHANGE_MEDIA (Cur 2 Tot 2)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.297999 99.73% [DEBUG] switch_core_state_machine.c:650 (sofia/external/0817145779) State EXCHANGE_MEDIA
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.297999 99.73% [DEBUG] mod_sofia.c:672 SOFIA EXCHANGE_MEDIA
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.317996 99.73% [DEBUG] switch_rtp.c:7125 Correct audio RTCP ip/port confirmed.
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:24.317996 99.73% [DEBUG] switch_rtp.c:7695 Correct audio ip/port confirmed.
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.338002 99.73% [DEBUG] switch_rtp.c:1930 rtcp_stats_init: audio ssrc[1365846142] base_seq[11325]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:24.338002 99.73% [DEBUG] switch_rtp.c:7695 Correct audio ip/port confirmed.
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] sofia.c:7493 Channel sofia/external/0817145779 entering state [proceeding][180]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] sofia.c:7500 Duplicate SDP
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] switch_core_media.c:5588 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] switch_core_media.c:5438 Set telephone-event payload to 101@8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] switch_core_media.c:5798 Set telephone-event payload to 101@8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] switch_core_media.c:5856 sofia/external/0817145779 Set 2833 dtmf send payload to 101 recv payload to 101
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:27.857991 99.70% [DEBUG] switch_core_media.c:8642 Audio params are unchanged for sofia/external/0817145779.
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] sofia.c:7493 Channel sofia/external/0817145779 entering state [proceeding][180]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] sofia.c:7500 Duplicate SDP
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] switch_core_media.c:5588 Audio Codec Compare [PCMA:8:8000:20:64000:1] ++++ is saved as a match
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] switch_core_media.c:5526 Audio Codec Compare [PCMA:8:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] switch_core_media.c:5438 Set telephone-event payload to 101@8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] switch_core_media.c:5798 Set telephone-event payload to 101@8000
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] switch_core_media.c:5856 sofia/external/0817145779 Set 2833 dtmf send payload to 101 recv payload to 101
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:29.537996 99.67% [DEBUG] switch_core_media.c:8642 Audio params are unchanged for sofia/external/0817145779.
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:41.377991 99.53% [DEBUG] sofia.c:7493 Channel sofia/external/0817145779 entering state [completing][200]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:41.377991 99.53% [DEBUG] sofia.c:7500 Duplicate SDP
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:41.397992 99.53% [DEBUG] sofia.c:7493 Channel sofia/external/0817145779 entering state [ready][200]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:41.397992 99.53% [NOTICE] sofia.c:8622 Channel [sofia/external/0817145779] has been answered
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:41.397992 99.53% [DEBUG] switch_channel.c:3912 (sofia/external/0817145779) Callstate Change EARLY -> ACTIVE
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:41.417991 99.53% [DEBUG] switch_core_media.c:8642 Audio params are unchanged for sofia/internal/101@pbx.example.co.id.
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:41.417991 99.53% [DEBUG] mod_sofia.c:914 Local SDP sofia/internal/101@pbx.example.co.id:
01decfd8-7b25-4d93-af4c-82bba64797c7 o=FreeSWITCH 1708450156 1708450158 IN IP4 149.129.248.234
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:41.417991 99.53% [NOTICE] switch_ivr_bridge.c:730 Channel [sofia/internal/101@pbx.example.co.id] has been answered
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:41.417991 99.53% [DEBUG] switch_channel.c:3912 (sofia/internal/101@pbx.example.co.id) Callstate Change EARLY -> ACTIVE
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:41.417991 99.53% [DEBUG] sofia.c:7493 Channel sofia/internal/101@pbx.example.co.id entering state [completed][200]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:41.437992 99.53% [DEBUG] sofia.c:7493 Channel sofia/internal/101@pbx.example.co.id entering state [ready][200]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:41.457990 99.53% [DEBUG] switch_rtp.c:7695 Correct audio ip/port confirmed.
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:41.457990 99.53% [DEBUG] switch_rtp.c:7695 Correct audio ip/port confirmed.
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:43.677996 99.47% [DEBUG] switch_rtp.c:7125 Correct audio RTCP ip/port confirmed.
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [NOTICE] sofia.c:1065 Hangup sofia/external/0817145779 [CS_EXCHANGE_MEDIA] [NORMAL_CLEARING]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_ivr_bridge.c:911 BRIDGE THREAD DONE [sofia/external/0817145779]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:650 (sofia/external/0817145779) State EXCHANGE_MEDIA going to sleep
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:581 (sofia/external/0817145779) Running State Change CS_HANGUP (Cur 2 Tot 2)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:844 (sofia/external/0817145779) Callstate Change ACTIVE -> HANGUP
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:846 (sofia/external/0817145779) State HANGUP
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] mod_sofia.c:469 Channel sofia/external/0817145779 hanging up, cause: NORMAL_CLEARING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:59 sofia/external/0817145779 Standard HANGUP, cause: NORMAL_CLEARING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:846 (sofia/external/0817145779) State HANGUP going to sleep
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:616 (sofia/external/0817145779) State Change CS_HANGUP -> CS_REPORTING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:581 (sofia/external/0817145779) Running State Change CS_REPORTING (Cur 2 Tot 2)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:932 (sofia/external/0817145779) State REPORTING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:168 sofia/external/0817145779 Standard REPORTING, cause: NORMAL_CLEARING
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:932 (sofia/external/0817145779) State REPORTING going to sleep
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_state_machine.c:607 (sofia/external/0817145779) State Change CS_REPORTING -> CS_DESTROY
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.737997 99.50% [DEBUG] switch_core_session.c:1744 Session 2 (sofia/external/0817145779) Locked, Waiting on external entities
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_ivr_bridge.c:819 sofia/external/0817145779 ending bridge by request from write function
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_ivr_bridge.c:911 BRIDGE THREAD DONE [sofia/internal/101@pbx.example.co.id]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [NOTICE] switch_ivr_bridge.c:1942 Hangup sofia/internal/101@pbx.example.co.id [CS_EXECUTE] [NORMAL_CLEARING]
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.757991 99.60% [NOTICE] switch_core_session.c:1762 Session 2 (sofia/external/0817145779) Ended
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.757991 99.60% [NOTICE] switch_core_session.c:1766 Close Channel sofia/external/0817145779 [CS_DESTROY]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_session.c:2979 sofia/internal/101@pbx.example.co.id skip receive message [APPLICATION_EXEC_COMPLETE] (channel is hungup already)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:647 (sofia/internal/101@pbx.example.co.id) State EXECUTE going to sleep
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/101@pbx.example.co.id) Running State Change CS_HANGUP (Cur 1 Tot 2)
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:735 (sofia/external/0817145779) Running State Change CS_DESTROY (Cur 1 Tot 2)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:844 (sofia/internal/101@pbx.example.co.id) Callstate Change ACTIVE -> HANGUP
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:745 (sofia/external/0817145779) State DESTROY
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.757991 99.60% [DEBUG] mod_sofia.c:380 sofia/external/0817145779 SOFIA DESTROY
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:846 (sofia/internal/101@pbx.example.co.id) State HANGUP
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:175 sofia/external/0817145779 Standard DESTROY
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] mod_sofia.c:463 sofia/internal/101@pbx.example.co.id Overriding SIP cause 480 with 200 from the other leg
efbe0fc4-54b1-4f4e-b66a-b36845d8d970 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:745 (sofia/external/0817145779) State DESTROY going to sleep
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] mod_sofia.c:469 Channel sofia/internal/101@pbx.example.co.id hanging up, cause: NORMAL_CLEARING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] mod_sofia.c:523 Sending BYE to sofia/internal/101@pbx.example.co.id
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:59 sofia/internal/101@pbx.example.co.id Standard HANGUP, cause: NORMAL_CLEARING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:846 (sofia/internal/101@pbx.example.co.id) State HANGUP going to sleep
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:616 (sofia/internal/101@pbx.example.co.id) State Change CS_HANGUP -> CS_REPORTING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/101@pbx.example.co.id) Running State Change CS_REPORTING (Cur 1 Tot 2)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:932 (sofia/internal/101@pbx.example.co.id) State REPORTING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:168 sofia/internal/101@pbx.example.co.id Standard REPORTING, cause: NORMAL_CLEARING
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:932 (sofia/internal/101@pbx.example.co.id) State REPORTING going to sleep
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:607 (sofia/internal/101@pbx.example.co.id) State Change CS_REPORTING -> CS_DESTROY
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_session.c:1744 Session 1 (sofia/internal/101@pbx.example.co.id) Locked, Waiting on external entities
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [NOTICE] switch_core_session.c:1762 Session 1 (sofia/internal/101@pbx.example.co.id) Ended
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [NOTICE] switch_core_session.c:1766 Close Channel sofia/internal/101@pbx.example.co.id [CS_DESTROY]
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:735 (sofia/internal/101@pbx.example.co.id) Running State Change CS_DESTROY (Cur 0 Tot 2)
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:745 (sofia/internal/101@pbx.example.co.id) State DESTROY
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] mod_sofia.c:380 sofia/internal/101@pbx.example.co.id SOFIA DESTROY
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:175 sofia/internal/101@pbx.example.co.id Standard DESTROY
01decfd8-7b25-4d93-af4c-82bba64797c7 2024-02-21 07:50:45.757991 99.60% [DEBUG] switch_core_state_machine.c:745 (sofia/internal/101@pbx.example.co.id) State DESTROY going to sleep
voipBull
42
Put the number you want the outbound calls blocked to in the 'Number' field instead of 'Name' field
