Voicemail Hangup Issues 5.3 Fresh Install
UCtech
36
Having issues with voicemail on a fresh install of 5.3. After the tone to leave a message the call is dropped. Otherwise everything works. I am wondering if this is due to using Freeswitch 1.10.12?
Install details:
Debian 12
Fusion 5.3 installed using Signalwire/Freeswitch token in config.sh (which by default installs the latest Freeswitch 1.10.12 instead of 1.10.11)
Fusion 5.3 updated to latest 5.3.4
UCtech
36
Logs show:
[WARNING] mod_sndfile.c:281 Error Opening File [/var/lib/freeswitch/storage/voicemail/default/mydomain/430/msg_04f331de-5c7d-425c-88f4-ee5c01582373.wav] [No Error.]
[NOTICE] switch_ivr_play_say.c:564 Hangup sofia/internal/ext@mydomain:5061 [CS_EXECUTE] [DESTINATION_OUT_OF_ORDER]
The 430 folder and all folders there are empty.
I looked in the 430 folder on a working system that has been upgraded instead of clean installed and it has lots of .wav files but not the same one. However it is Freeswitch 1.10.11.
Any ideas? revert to 1.10.11?
