Transfer calls impossible.
Tobey
Hi all, I am a beginner user of Fusionpbx, I would like to describe here my problem, which for you may turn out to be trivial (which I very much hope), below I will present my configuration, which I made originally, which does not work - I ask here for any advice/observations.
Specifically, I have two siptrunks named siptrunk1 and siptrunk2.
The call falls from siptrunk1 to the number 777100102, - this is a virtual number that is automatically forwarded to the number 102 after entering FusionPbx, this is the number registered on the physical phone on the desk, after 10 seconds of not answering the call is pushed to the next siptrunk “siptrunk2” on the queue 5023.
Below are the configuration slides:
2.
And the configured bridge to siptrunk2:
Maybe you guys will know what the error lies in, or how it should look properly?
Thank you beautifully in advance.
pbxgeek
146
53
One issue I saw right away is that you have a ring group with extension 102 and a destination 102 within that ring group. If 102 is an extension in your system, then you have a duplicate. Ring groups and extensions can not have the same extension number. It causes conflicts. I had to program my own code so the system checks for duplicates before saving new items.
