Tls issues
RTL
20
Been trying to enable tls for extensions to register. Followed this https://docs.fusionpbx.com/en/latest/additional_information/sip_tls.html
and found I had to change the tls value in the internal sip profile as well
Cleared the cache and rescan and I can get a handset registered with tls.
So far so good. Until 24 hours later the internal sip profile stopped. Now the only way I can get it started is Advanced > Variables and change internal_ssl_enable to false and change tls to flase in the internal sip profile.
The profile now starts. If I enable tls again and rescan then I'm back to tls on port 5061 and now handsets won't register. Finally, a reboot breaks this and I need to go through it all again.
Any ideas, comments
574
Also, if you do not get the required info in the log, in fs_cli do:
sofia loglevel all 9
You should see the problem in there though it is very verbose.
RTL
20
As the only change I made was enable tls I made a backup, restored from a backup from before those changes and we're back working.
I'll restore the 'non working' backup on a new server and investigate.
Having got a working system again, how do I move the call records over from the period between enabling tls and restoring the working backup
