setting extension to record outbound records internal/local calls too
wa4zlw
131
Blandon, PA
www.myinternetsupport.com
related to my earlier post on recording on outbound routes we started to look for alternative ways to record outbound calls.
we found in the extension settings a dropdown:
When set to INBOUND any local ext-2-ext calls as well as OUTBOUND calls are recorded. I would have expected no "Local" extension-2-extension calls to be recorded and only calls going ouotside the PBX be recorded.
AM I correct? If so is this a bug?
On 4.4.6/1.8.5
thanks leon
wa4zlw
131
Blandon, PA
Hi there....my previous post is not doing exactly what we need. We really need to record outbound calls on certain gateways/trunks. Inbound is working since it's going to a call center and we're recording that.
it looks like it could be part of the dialplan but I haven't figured out the exact action needed
thanks leon
