Ring Group and Time Conditions errors: address is incomplete
Good day all. Hope all is well there :) ?
Please can someone point in the right direction. I have an updated multi-tenant server. been running it for about 6 months, with 5 tenants so far.
Suddenly, since yesterday, I am having a very weird error on my biggest tenant (6 extensions) instance. The inbound call, destined to the ring group, gets an error "address is incomplete". I duplicated the install on my own domain on same server, and it works 100%, only applicable to the one domain.
This has been working for months, and suddenly started with the error. Has anyone here seen this, or can you please point me in the right direction...
204
That's a new one for me. I would start with clearing the cache, then delete existing ring group and recreate it.
Reactions: Nerdy Pbx
Also ad5ou, if I point the inbound destination to 100, being a time condition that has always worked. It errors with: "not found". Then I change the destination to 200, a normal extension, it works immediately? I am stumped, and this is costing my my reputation with my clients. Cant even begin to understand what happened...
204
Does seem odd.
To flush cache, Got to Status>Sip Status and Upper right will have a button to flush cache.
To extra sure it flushed, you can ssh into the server and check /var/chache/fusionpbx to make sure the files deleted or run "rm /var/cache/fusionpbx/*" to be super certain.
The files will recreate automatically as freeswitch needs them.
204
Creating/editing inbound routes and time conditions SHOULD update the cached dial plans but it doesn't always. I usually manually clear the cache after any updates to the inbound routes to make sure the changes are taken but it sounds like something else is going on.
It's hard to tell with out seeing the log of a failed call and a successful one.
Double check your time condition is showing up in Dialplans>Dialplan Manager. Usually order 300. Also delete/recreate the time condition if you haven't already.
I have since found all domains have the same challenge:
  • Time Conditions = "Not found" error
  • Ring groups = "address is incomplete"
  • Time Conditions seem "off". as if the time or region is incorrect, although server is set correctly, and default settings also correct.
If anyone has ever seen this please.... I have done al of the above with ad5ou's help (Thank you ad5ou!), but the issue remains. The minute I direct the inbound to an actual extension all is good. IVR's (using the 700's range) also works. Time conditions (on 100 range) and ring group (on 600 range) does not work.
It has been working for months, and suddenly this...(I have also ran the upgrades, both on the dashboard and in a SSL session, and rebooted the server)
Time conditions do show up yes ad5ou. Also did remove all, cleared cache manually, and recreated time conditions. no go. All domains now affected since reboot
81
What does the log viewer show when an inbound call takes place that fails? Might even be able to get away with what is displayed in the CDR detail logs?
did the test, but very confusing guys. Please if someone can assist:
When I point the inbound destination to a time condition, i get the "not found" error. Copy of log:
1 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State DESTROY going to sleep
2 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_state_machine.c:181 sofia/internal/200@nerdzone.nerdpbx.co.za:5060 Standard DESTROY
3 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] mod_sofia.c:364 sofia/internal/200@nerdzone.nerdpbx.co.za:5060 SOFIA DESTROY
4 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State DESTROY
5 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_state_machine.c:739 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) Running State Change CS_DESTROY (Cur 0 Tot 1974)
6 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [NOTICE] switch_core_session.c:1758 Close Channel sofia/internal/200@nerdzone.nerdpbx.co.za:5060 [CS_DESTROY]
7 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [NOTICE] switch_core_session.c:1754 Session 1971 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) Ended
8 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_session.c:1736 Session 1971 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) Locked, Waiting on external entities
9 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_state_machine.c:611 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State Change CS_REPORTING -> CS_DESTROY
10 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State REPORTING going to sleep
11 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:46.413075 [DEBUG] switch_core_state_machine.c:174 sofia/internal/200@nerdzone.nerdpbx.co.za:5060 Standard REPORTING, cause: NORMAL_CLEARING
12 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_state_machine.c:749 (sofia/external/27108805851@41.76.200.38) State DESTROY going to sleep
13 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_state_machine.c:181 sofia/external/27108805851@41.76.200.38 Standard DESTROY
14 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] mod_sofia.c:364 sofia/external/27108805851@41.76.200.38 SOFIA DESTROY
15 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_state_machine.c:749 (sofia/external/27108805851@41.76.200.38) State DESTROY
16 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_state_machine.c:739 (sofia/external/27108805851@41.76.200.38) Running State Change CS_DESTROY (Cur 1 Tot 1974)
17 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [NOTICE] switch_core_session.c:1758 Close Channel sofia/external/27108805851@41.76.200.38 [CS_DESTROY]
18 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [NOTICE] switch_core_session.c:1754 Session 1973 (sofia/external/27108805851@41.76.200.38) Ended
19 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_session.c:1736 Session 1973 (sofia/external/27108805851@41.76.200.38) Locked, Waiting on external entities
20 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_state_machine.c:611 (sofia/external/27108805851@41.76.200.38) State Change CS_REPORTING -> CS_DESTROY
21 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_state_machine.c:936 (sofia/external/27108805851@41.76.200.38) State REPORTING going to sleep
22 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:46.273006 [DEBUG] switch_core_state_machine.c:174 sofia/external/27108805851@41.76.200.38 Standard REPORTING, cause: NORMAL_CLEARING
23 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State REPORTING
24 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) Running State Change CS_REPORTING (Cur 2 Tot 1974)
25 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_state_machine.c:620 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State Change CS_HANGUP -> CS_REPORTING
26 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State HANGUP going to sleep
27 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_state_machine.c:60 sofia/internal/200@nerdzone.nerdpbx.co.za:5060 Standard HANGUP, cause: NORMAL_CLEARING
28 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] mod_sofia.c:598 Responding to INVITE with: 404
29 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] mod_sofia.c:453 Channel sofia/internal/200@nerdzone.nerdpbx.co.za:5060 hanging up, cause: NORMAL_CLEARING
30 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] mod_sofia.c:447 sofia/internal/200@nerdzone.nerdpbx.co.za:5060 Overriding SIP cause 480 with 404 from the other leg
31 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State HANGUP
32 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_state_machine.c:848 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) Callstate Change EARLY -> HANGUP
33 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_core_media_bug.c:1312 Removing BUG from sofia/internal/200@nerdzone.nerdpbx.co.za:5060
34 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.653001 [DEBUG] switch_ivr_async.c:1597 Channel is hung up
35 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.633000 [DEBUG] switch_core_state_machine.c:749 (sofia/external/0119541139) State DESTROY going to sleep
36 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.633000 [DEBUG] switch_core_state_machine.c:181 sofia/external/0119541139 Standard DESTROY
37 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.633000 [DEBUG] mod_sofia.c:364 sofia/external/0119541139 SOFIA DESTROY
38 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.633000 [DEBUG] switch_core_state_machine.c:749 (sofia/external/0119541139) State DESTROY
39 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.633000 [DEBUG] switch_core_state_machine.c:739 (sofia/external/0119541139) Running State Change CS_DESTROY (Cur 2 Tot 1974)
40 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.633000 [NOTICE] switch_core_session.c:1758 Close Channel sofia/external/0119541139 [CS_DESTROY]
41 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.633000 [NOTICE] switch_core_session.c:1754 Session 1972 (sofia/external/0119541139) Ended
42 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.633000 [DEBUG] switch_ivr_async.c:1520 Stop recording file /var/lib/freeswitch/recordings/nerdzone.nerdpbx.co.za/archive/2021/May/17/e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3.wav
43 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.633000 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) Running State Change CS_HANGUP (Cur 3 Tot 1974)
44 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.633000 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/200@nerdzone.nerdpbx.co.za:5060) State EXECUTE going to sleep
45 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.633000 [NOTICE] switch_core_state_machine.c:388 Hangup sofia/internal/200@nerdzone.nerdpbx.co.za:5060 [CS_EXECUTE] [NORMAL_CLEARING]
46 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.633000 [NOTICE] switch_core_state_machine.c:386 sofia/internal/200@nerdzone.nerdpbx.co.za:5060 has executed the last dialplan instruction, hanging up.
47 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.633000 [DEBUG] switch_ivr_bridge.c:912 BRIDGE THREAD DONE [sofia/internal/200@nerdzone.nerdpbx.co.za:5060]
48 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.633000 [DEBUG] switch_ivr_bridge.c:820 sofia/external/0119541139 ending bridge by request from write function
49 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_session.c:1736 Session 1972 (sofia/external/0119541139) Locked, Waiting on external entities
50 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:611 (sofia/external/0119541139) State Change CS_REPORTING -> CS_DESTROY
51 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:936 (sofia/external/0119541139) State REPORTING going to sleep
52 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:174 sofia/external/0119541139 Standard REPORTING, cause: UNALLOCATED_NUMBER
53 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:936 (sofia/external/0119541139) State REPORTING
54 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:585 (sofia/external/0119541139) Running State Change CS_REPORTING (Cur 3 Tot 1974)
55 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:620 (sofia/external/0119541139) State Change CS_HANGUP -> CS_REPORTING
56 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:850 (sofia/external/0119541139) State HANGUP going to sleep
57 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:60 sofia/external/0119541139 Standard HANGUP, cause: UNALLOCATED_NUMBER
58 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] mod_sofia.c:453 Channel sofia/external/0119541139 hanging up, cause: UNALLOCATED_NUMBER
59 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:850 (sofia/external/0119541139) State HANGUP
60 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:848 (sofia/external/0119541139) Callstate Change EARLY -> HANGUP
61 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:585 (sofia/external/0119541139) Running State Change CS_HANGUP (Cur 3 Tot 1974)
62 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_core_state_machine.c:654 (sofia/external/0119541139) State EXCHANGE_MEDIA going to sleep
63 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_ivr_bridge.c:912 BRIDGE THREAD DONE [sofia/external/0119541139]
64 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] switch_ivr_bridge.c:826 sofia/external/0119541139 ending bridge by request from read function
65 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [NOTICE] sofia.c:8641 Hangup sofia/external/0119541139 [CS_EXCHANGE_MEDIA] [UNALLOCATED_NUMBER]
66 278ff527-8ce6-4eef-98b6-87e9fbdc4705 2021-05-17 19:13:45.612999 [DEBUG] sofia.c:7406 Channel sofia/external/0119541139 entering state [terminated][404]
67 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_state_machine.c:936 (sofia/external/27108805851@41.76.200.38) State REPORTING
68 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_state_machine.c:585 (sofia/external/27108805851@41.76.200.38) Running State Change CS_REPORTING (Cur 3 Tot 1974)
69 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_state_machine.c:620 (sofia/external/27108805851@41.76.200.38) State Change CS_HANGUP -> CS_REPORTING
70 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_state_machine.c:850 (sofia/external/27108805851@41.76.200.38) State HANGUP going to sleep
71 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_state_machine.c:60 sofia/external/27108805851@41.76.200.38 Standard HANGUP, cause: NORMAL_CLEARING
72 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] mod_sofia.c:598 Responding to INVITE with: 404
73 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] mod_sofia.c:453 Channel sofia/external/27108805851@41.76.200.38 hanging up, cause: NORMAL_CLEARING
74 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] mod_sofia.c:447 sofia/external/27108805851@41.76.200.38 Overriding SIP cause 480 with 404 from the other leg
75 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_state_machine.c:850 (sofia/external/27108805851@41.76.200.38) State HANGUP
76 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_state_machine.c:848 (sofia/external/27108805851@41.76.200.38) Callstate Change EARLY -> HANGUP
77 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_core_media_bug.c:1312 Removing BUG from sofia/external/27108805851@41.76.200.38
78 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.573041 [DEBUG] switch_ivr_async.c:1597 Channel is hung up
79 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.553010 [DEBUG] switch_core_state_machine.c:749 (sofia/external/100) State DESTROY going to sleep
80 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.553010 [DEBUG] switch_core_state_machine.c:181 sofia/external/100 Standard DESTROY
81 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.553010 [DEBUG] mod_sofia.c:364 sofia/external/100 SOFIA DESTROY
82 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.553010 [DEBUG] switch_core_state_machine.c:749 (sofia/external/100) State DESTROY
83 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.553010 [DEBUG] switch_core_state_machine.c:739 (sofia/external/100) Running State Change CS_DESTROY (Cur 3 Tot 1974)
84 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.553010 [NOTICE] switch_core_session.c:1758 Close Channel sofia/external/100 [CS_DESTROY]
85 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.553010 [NOTICE] switch_core_session.c:1754 Session 1974 (sofia/external/100) Ended
86 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.553010 [DEBUG] switch_ivr_async.c:1520 Stop recording file /var/lib/freeswitch/recordings/neb.nerdpbx.co.za/archive/2021/May/17/9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e.wav
87 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.553010 [DEBUG] switch_core_state_machine.c:585 (sofia/external/27108805851@41.76.200.38) Running State Change CS_HANGUP (Cur 4 Tot 1974)
88 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.553010 [DEBUG] switch_core_state_machine.c:651 (sofia/external/27108805851@41.76.200.38) State EXECUTE going to sleep
89 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.553010 [NOTICE] switch_core_state_machine.c:388 Hangup sofia/external/27108805851@41.76.200.38 [CS_EXECUTE] [NORMAL_CLEARING]
90 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.553010 [NOTICE] switch_core_state_machine.c:386 sofia/external/27108805851@41.76.200.38 has executed the last dialplan instruction, hanging up.
91 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.553010 [INFO] mod_dptools.c:3643 Originate Failed. Cause: UNALLOCATED_NUMBER
92 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.553010 [DEBUG] switch_ivr_originate.c:4026 Originate Resulted in Error Cause: 1 [UNALLOCATED_NUMBER]
93 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_session.c:1736 Session 1974 (sofia/external/100) Locked, Waiting on external entities
94 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:611 (sofia/external/100) State Change CS_REPORTING -> CS_DESTROY
95 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:936 (sofia/external/100) State REPORTING going to sleep
96 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:174 sofia/external/100 Standard REPORTING, cause: UNALLOCATED_NUMBER
97 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:936 (sofia/external/100) State REPORTING
98 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:585 (sofia/external/100) Running State Change CS_REPORTING (Cur 4 Tot 1974)
99 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:620 (sofia/external/100) State Change CS_HANGUP -> CS_REPORTING
100 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:850 (sofia/external/100) State HANGUP going to sleep
101 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:60 sofia/external/100 Standard HANGUP, cause: UNALLOCATED_NUMBER
102 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] mod_sofia.c:453 Channel sofia/external/100 hanging up, cause: UNALLOCATED_NUMBER
103 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:850 (sofia/external/100) State HANGUP
104 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:848 (sofia/external/100) Callstate Change DOWN -> HANGUP
105 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] switch_core_state_machine.c:585 (sofia/external/100) Running State Change CS_HANGUP (Cur 4 Tot 1974)
106 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [NOTICE] sofia.c:8641 Hangup sofia/external/100 [CS_CONSUME_MEDIA] [UNALLOCATED_NUMBER]
107 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.533010 [DEBUG] sofia.c:7406 Channel sofia/external/100 entering state [terminated][404]
108 e0954b82-c56d-4d0c-9c3c-0bb2ac8ec0a3 2021-05-17 19:13:45.313005 [INFO] switch_rtp.c:7753 Auto Changing audio port from 192.168.0.147:11996 to 156.155.159.140:11996
109 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.273009 [DEBUG] switch_core_io.c:448 Setting BUG Codec PCMU:0
110 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.273009 [DEBUG] switch_rtp.c:7793 Correct audio ip/port confirmed.
111 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] sofia.c:7406 Channel sofia/external/100 entering state [calling][0]
112 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.252997 [DEBUG] switch_ivr_async.c:1717 No silence detection configured; assuming start of speech
113 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:663 (sofia/external/100) State CONSUME_MEDIA going to sleep
114 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:663 (sofia/external/100) State CONSUME_MEDIA
115 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:585 (sofia/external/100) Running State Change CS_CONSUME_MEDIA (Cur 4 Tot 1974)
116 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:644 (sofia/external/100) State ROUTING going to sleep
117 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_ivr_originate.c:67 (sofia/external/100) State Change CS_ROUTING -> CS_CONSUME_MEDIA
118 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] mod_sofia.c:154 sofia/external/100 SOFIA ROUTING
119 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:644 (sofia/external/100) State ROUTING
120 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] sofia.c:7406 Channel sofia/external/100 entering state [calling][0]
121 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:585 (sofia/external/100) Running State Change CS_ROUTING (Cur 4 Tot 1974)
122 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:628 (sofia/external/100) State INIT going to sleep
123 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:48 (sofia/external/100) State Change CS_INIT -> CS_ROUTING
124 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:40 sofia/external/100 Standard INIT
125 656d6f16-41b8-4911-b40c-ff785bcc0d92
126 656d6f16-41b8-4911-b40c-ff785bcc0d92 a=sendrecv
127 656d6f16-41b8-4911-b40c-ff785bcc0d92 a=ptime:20
128 656d6f16-41b8-4911-b40c-ff785bcc0d92 a=silenceSupp:eek:ff - - - -
129 656d6f16-41b8-4911-b40c-ff785bcc0d92 a=fmtp:101 0-16
130 656d6f16-41b8-4911-b40c-ff785bcc0d92 a=rtpmap:101 telephone-event/8000
131 656d6f16-41b8-4911-b40c-ff785bcc0d92 a=rtpmap:8 PCMA/8000
132 656d6f16-41b8-4911-b40c-ff785bcc0d92 a=rtpmap:0 PCMU/8000
133 656d6f16-41b8-4911-b40c-ff785bcc0d92 m=audio 17128 RTP/AVP 0 8 101
134 656d6f16-41b8-4911-b40c-ff785bcc0d92 t=0 0
135 656d6f16-41b8-4911-b40c-ff785bcc0d92 c=IN IP4 197.234.22.237
136 656d6f16-41b8-4911-b40c-ff785bcc0d92 s=FreeSWITCH
137 656d6f16-41b8-4911-b40c-ff785bcc0d92 o=FreeSWITCH 1621254497 1621254498 IN IP4 197.234.22.237
138 656d6f16-41b8-4911-b40c-ff785bcc0d92 v=0
139 656d6f16-41b8-4911-b40c-ff785bcc0d92 Local SDP:
140 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] sofia_glue.c:1624 sofia/external/100 sending invite version: 1.10.6 -release-18-1ff9d0a60e 64bit
141 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [INFO] sofia_glue.c:1621 sofia/external/100 sending invite call-id: (null)
142 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] mod_sofia.c:93 sofia/external/100 SOFIA INIT
143 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:628 (sofia/external/100) State INIT
144 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.252997 [DEBUG] switch_core_state_machine.c:585 (sofia/external/100) Running State Change CS_INIT (Cur 4 Tot 1974)
145 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.232995 [DEBUG] mod_sofia.c:5102 (sofia/external/100) State Change CS_NEW -> CS_INIT
146 656d6f16-41b8-4911-b40c-ff785bcc0d92 2021-05-17 19:13:45.232995 [NOTICE] switch_channel.c:1118 New Channel sofia/external/100 [656d6f16-41b8-4911-b40c-ff785bcc0d92]
147 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_ivr_originate.c:2272 Parsing global variables
148 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:1264 sofia/external/27108805851@41.76.200.38 EXPORTING[export_vars] [call_direction]=[outbound] to event
149 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:1264 sofia/external/27108805851@41.76.200.38 EXPORTING[export_vars] [origination_callee_id_name]=[100] to event
150 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:1264 sofia/external/27108805851@41.76.200.38 EXPORTING[export_vars] [hold_music]=[local_stream://default] to event
151 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:1264 sofia/external/27108805851@41.76.200.38 EXPORTING[export_vars] [call_direction]=[outbound] to event
152 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:1264 sofia/external/27108805851@41.76.200.38 EXPORTING[export_vars] [call_direction]=[outbound] to event
153 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 bridge(sofia/gateway/154a5d4c-2790-422a-885f-b8ca546f5f30/100)
154 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [continue_on_fail]=[true]
155 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(continue_on_fail=true)
156 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [callee_id_number]=[100]
157 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(callee_id_number=100)
158 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [ignore_display_updates]=[true]
159 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(ignore_display_updates=true)
160 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [inherit_codec]=[true]
161 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(inherit_codec=true)
162 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [effective_caller_id_number]=[UNDEF]
163 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(effective_caller_id_number=)
164 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [effective_caller_id_name]=[UNDEF]
165 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(effective_caller_id_name=)
166 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [hangup_after_bridge]=[true]
167 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(hangup_after_bridge=true)
168 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1830 UNSET [call_timeout]
169 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 unset(call_timeout)
170 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [call_direction]=[outbound]
171 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 export(call_direction=outbound)
172 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [sip_h_X-accountcode]=[UNDEF]
173 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(sip_h_X-accountcode=)
174 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 hash(insert/neb.nerdpbx.co.za-last_dial/27108805851/100)
175 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [origination_callee_id_name]=[100]
176 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 export(origination_callee_id_name=100)
177 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [RFC2822_DATE]=[Mon, 17 May 2021 19:13:45 +0200]
178 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(RFC2822_DATE=Mon, 17 May 2021 19:13:45 +0200)
179 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_core_state_machine.c:329 sofia/external/27108805851@41.76.200.38 Standard EXECUTE
180 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_sofia.c:209 sofia/external/27108805851@41.76.200.38 SOFIA EXECUTE
181 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_core_state_machine.c:651 (sofia/external/27108805851@41.76.200.38) State EXECUTE
182 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_channel.c:2336 (sofia/external/27108805851@41.76.200.38) Callstate Change RINGING -> EARLY
183 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_core_state_machine.c:585 (sofia/external/27108805851@41.76.200.38) Running State Change CS_EXECUTE (Cur 3 Tot 1973)
184 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_core_state_machine.c:644 (sofia/external/27108805851@41.76.200.38) State ROUTING going to sleep
185 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] switch_core_state_machine.c:287 (sofia/external/27108805851@41.76.200.38) State Change CS_ROUTING -> CS_EXECUTE
186 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action bridge(sofia/gateway/154a5d4c-2790-422a-885f-b8ca546f5f30/100)
187 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(continue_on_fail=true)
188 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(callee_id_number=100)
189 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(ignore_display_updates=true)
190 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(inherit_codec=true)
191 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(effective_caller_id_number=${outbound_caller_id_number})
192 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(effective_caller_id_name=${outbound_caller_id_name})
193 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(hangup_after_bridge=true)
194 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action unset(call_timeout)
195 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action export(call_direction=outbound)
196 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(sip_h_X-accountcode=${accountcode})
197 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Regex (PASS) [Neb Sip.d] destination_number(100) =~ /^(\d+)$/ break=on-false
198 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Regex (PASS) [Neb Sip.d] ${user_exists}(false) =~ /false/ break=on-false
199 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 parsing [neb.nerdpbx.co.za->Neb Sip.d] continue=false
200 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [outbound_caller_id_number]=[UNDEF]
201 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(outbound_caller_id_number=)
202 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
203 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
204 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [outbound_caller_id_name]=[UNDEF]
205 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(outbound_caller_id_name=)
206 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
207 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Regex (PASS) [default_caller_id] ${outbound_caller_id_name}() =~ /^$/ break=never
208 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [emergency_caller_id_number]=[UNDEF]
209 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(emergency_caller_id_number=)
210 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
211 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
212 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e 2021-05-17 19:13:45.232995 [DEBUG] mod_dptools.c:1685 SET sofia/external/27108805851@41.76.200.38 [emergency_caller_id_name]=[UNDEF]
213 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e EXECUTE [depth=0] sofia/external/27108805851@41.76.200.38 set(emergency_caller_id_name=)
214 9c5c19b1-096a-4a1a-8dc7-cfd6ae403e0e Dialplan: sofia/external/27108805851@41.76.200.38 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
215 41.76.200.38 Regex (PASS) [default_caller_id] ${emergency_caller_id_name}() =~ /^$/ break=never
81
Have you got some conflicting outbound routes here, perhaps not in the best order for the dialplan? The reason I ask is it appears that it tries to bridge that 100 out to a gateway. It's incredibly common here, when the techs try to set up outbound routes for 3 digit services (999, 911, 101, etc) but they don't make sure the order is something last resort like 901.
