Recordings on other hard drive, Moving it in live environment, Possible? any input appreciated!
bdmonsey
152
My server is filling up with recordings, i'm to 95% i do have an additional hard drive mounted to this server, whats the easiest and safest way moving over the old files and setting that all recordings from now to go to the new hard drive?
And at the same time, is is possible to store on like google drive or any other external syncing backup software?
204
The script below will probably help save some space. This requires "ffmpeg" to convert the wav files to opus.
You will need to modify the directories to match your environment. My system records directly to a secondary dive mounted to "/mnt/retain"
The script runs during the night to convert "yesterday's" wav files to the space saving opus versions and updates database.
There are a few other versions of this script posted here on the forums.
Bash:
#!/bin/sh
#  Needs ffmpeg to work.  Verify recordings directory and set database PW
PGPASSWORD="$(grep db_password /etc/fusionpbx/config.php | cut -d "'" -f2)"
export PGPASSWORD
echo $(date -u) "conversions started" >> /root/convert.log
#Find wav files from yesterday and convert them to opus, then delete original fi        les, then update xml cdr and call recording database entries
for DIRECTORY in /mnt/retain/*/; do
  DIRYESTERDAY=/mnt/retain/`basename "$DIRECTORY"`/archive/`date -d "yesterday"        +%Y/%b/%d`
    if [ -d "$DIRYESTERDAY" ]; then
      for WAVFILE in /mnt/retain/`basename "$DIRECTORY"`/archive/`date -d 'yeste        rday' +%Y/%b/%d`/*.wav; do
      BNAME=`basename $WAVFILE .wav`
echo $BNAME
        ffmpeg -i $WAVFILE -c:a libopus -b:a 8k $DIRYESTERDAY/$BNAME.ogg >> /dev        /null
        psql --host=127.0.0.1 --username=fusionpbx -t -c "UPDATE v_call_recordin        gs SET call_recording_name = '$BNAME.ogg' WHERE call_recording_name = '$BNAME.wa        v' and call_recording_path = '$DIRYESTERDAY'"
        psql --host=127.0.0.1 --username=fusionpbx -t -c "UPDATE v_xml_cdr set r        ecord_name = '$BNAME.ogg' WHERE record_name = '$BNAME.wav'"
      done
    rm $DIRYESTERDAY/*.wav
    fi
 chown -R www-data:www-data $DIRYESTERDAY/*
done
# run again for plain -archive- directory calls
  DIRYESTERDAY=/mnt/retain/`basename "$DIRECTORY"`/`date -d "yesterday" +%Y/%b/%        d`
      for WAVFILE in /mnt/retain/`basename "$DIRECTORY"`/`date -d 'yesterday' +%        Y/%b/%d`/*.wav; do
echo $BNAME
      done
    fi
done
echo $(date -u) "conversions complete" >> /root/convert.log
find /mnt/retain/* -name '*.tar.bz2' -mtime +3 -exec rm {} \;
