SOLVED p-asserted-identity sip header
krooney
166
16
Hi our provider is asking for this
When sending calls you must put the pilot number in the p-asserted-identity sip header in full E164 format (+CC<phone number>). All other phone numbers must be in full E164 format (+CC<phone number>).
what is the easiest and best way to do this.
Thanks in advance!
whut
207
19
I would set the extension CID number in E164 as pbxgeek suggested. Then check your cdr call logs, sngrep, and verify it it meeting the provider's request.
