I have a domestic carrier (gateway) that works fine, but they do not provide international calls, only domestic calls. I just setup an international carrier (gateway) and the calls fail. I am using the default international dial plan expression provided in FusionPBX: ^(011\d{9,17})$
When I setup my domestic gateway using the default North American Dial Plan I did have to modify the bridge statement in the dial plan. It was by default this: sofia/gateway/xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/$1, and I changed it to this: sofia/gateway/xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/1$1. It did not work until I added the 1. I think the first "1 " appends to the phone number dialed, but I am not sure.
Anyway, I am wondering if there is a change I must make to my international dial plan or if it is something else. I did find an error in the call log which says NORMAL_TEMPORARY_FAILURE, which implies to me the problem is with my gateway, but I don't know.
I attached a copy of the log file to this post, (private info is masked) if anyone can help I would really appreciate it. I started this project a year ago, and I still don't have any customers. I would really like to get it into production so I can make a little green.
