Hi Everyone, I'm trying to provision OPUS and G722 to my Yealink T46U. G722 provisions fine, but OPUS simply does not appear. If I try to provision OPUS alone, no codecs provision to the phone at all.
I have attached a screenshot of the applicable provisioning section of Default Settings.
Thanks for any help you can give!
EDIT: Prior to provisioning, upon logging into the web console of my phones and manually enabling OPUS, OPUS works fine on all extensions. However something about provisioning is breaking OPUS. I can't get OPUS to appear in the enabled codec list after provisioning, and even upon manually turning OPUS on in the web interface of the phone, it still doesn't work post-provisioning, whereas it does pre-provisioning.
