No Incoming call on DID
Rasreby
VoIP trunk registration is good, outbound calls are fine but no incoming calls. Fusion PBX 5.3 and below is what I see in the Log file. I have gone ahead and create a new domain and user name as requested by the log file but still no luck. See below for log file entry.
2024-11-27 07:19:19.227096 99.53% [WARNING] sofia_reg.c:3210 Can't find user [XXXXXX_Trunk@142.1x7.7x.xx7] from 208.100.6x.5x
You must define a domain called 142.1x7.7x.xx7' in your directory and add a user with the id="XXXX_Trunk" attribute
410db780-3551-4733-b7b9-b6c7c46995df 2024-11-27 07:19:19.227096 99.53% [NOTICE] sofia.c:2417 Hangup sofia/internal/43744XXXXX@208.100.6x.5x [CS_NEW] [CALL_REJECTED]
410db780-3551-4733-b7b9-b6c7c46995df 2024-11-27 07:19:19.246941 99.53% [DEBUG] sofia.c:1527 Channel is already hungup.
410db780-3551-4733-b7b9-b6c7c46995df 2024-11-27 07:19:19.246941 99.53% [DEBUG] switch_core_state_machine.c:581 (sofia/internal/4374462748@208.100.60.55) Running State Change CS_HANGUP (Cur 1 Tot 6)
410db780-3551-4733-b7b9-b6c7c46995df 2024-11-27 07:19:19.246941 99.53% [DEBUG] switch_core_state_machine.c:844 (sofia/internal/4374462748@208.100.60.55) Callstate Change DOWN -> HANGUP
