SOLVED No CDR on Call Detail Records
ksargeant
22
Hi Guys,
I have just read every other post pertaining to the CDR records.
I have:
  • Commented out:
<!-- <param name="url" value="http://127.0.0.1/app/xml_cdr/xml_cdr_import.php"/>-->
  • Confirmed that xml_cdr is present:
cp /var/www/fusionpbx/app/xml_cdr/resources/service/debian.service /etc/systemd/system/xml_cdr.service
systemctl enable xml_cdr
systemctl start xml_cdr
systemctl daemon-reload
  • Reloaded
fs_cli -x 'reload mod_xml_cdr'
  • Confirmed there are cdr records
root@FusionPBX:~# cd /var/log/freeswitch/xml_cdr
ls -lh
You have new mail in /var/mail/root
total 776K
-rwxr-xr-x 1 www-data www-data 18K Mar 22 19:45 a_06f1af4e-2d07-43e8-9d75-5d2ae4355b34.cdr.xml
-rwxr-xr-x 1 www-data www-data 29K Mar 22 20:20 a_07ceaf80-b5dd-4471-b454-12870d2fb794.cdr.xm
l
  • Confirmed cron is active and working:
2025-03-22T21:29:01.685257+00:00 FusionPBX CRON[581]: (root) CMD (/bin/php /var/www/fusionpbx/app/xml_cdr/xml_cdr_import.php 300)
2025-03-22T21:30:01.768667+00:00 FusionPBX CRON[611]: (root) CMD (/bin/php /var/www/fusionpbx/app/xml_cdr/xml_cdr_import.php 300)
2025-03-22T21:31:01.846127+00:00 FusionPBX CRON[636]: (root) CMD (/bin/php /var/www/fusionpbx/app/xml_cdr/xml_cdr_import.php 300)
  • Make a test call
Am I doing something wrong here?
After a very insightful call with Mark the issue has been resolved and we have deemed this to be a Proxmox specific issue. The parent issue is found here: https://www.pbxforums.com/threads/fresh-install-proxmox-freeswitch-service-failed.8344/
As a result of the above fail, it stops Freeswitch from updating all of the directories in Advanced > Default Settings > Switch
The fix:
Got to Advanced > Default Settings > Switch
Select all in the Switch Category > Delete
Head to Advanced > Upgrade > App Defaults > Execute
Wallah - Your CDR records will be showing in the GUI.
Reactions: DigitalDaz
