Call Details
A detailed view of the call and all information regarding it. The information contains Caller ID Name and Number, channel data, call variables, call flow, timing information, and other useful call details.
Summary
Direction Name Number Destination Start End Hangup Cause Duration Status
outbound +13675006555 +13675006555 7373131362 2024-12-03 20:05:40 2024-12-03 20:05:55 ORIGINATOR_CANCEL 0:00:00 Cancelled
Call Flow Summary
Application Source Destination Name Start End Duration Status
Extensions +13675006555 +12394566369 2024-12-03 20:05:40 2024-12-03 20:05:40 0:00:00 Missed
Extensions +13675006555 100 2024-12-03 20:05:40 2024-12-03 20:05:40 0:00:00 Missed
Extensions +13675006555 7373131362 2024-12-03 20:05:43 2024-12-03 20:05:55 0:00:12 Cancelled
Call Stats: Audio: inbound
Name Value
mos 4.50
raw_bytes 0
flaw_total 0
media_bytes 0
packet_count 0
mean_interval 0.00
largest_jb_size 0
cng_packet_count 0
jitter_loss_rate 0.00
dtmf_packet_count 0
jitter_burst_rate 0.00
skip_packet_count 587
flush_packet_count 0
media_packet_count 0
quality_percentage 100.00
jitter_max_variance 0.00
jitter_min_variance 0.00
jitter_packet_count 0
Call Stats: Audio: outbound
Name Value
raw_bytes 0
media_bytes 0
packet_count 0
cng_packet_count 0
rtcp_octet_count 0
dtmf_packet_count 0
rtcp_packet_count 0
skip_packet_count 0
Channel Data
Name Value
caps 1=1;2=1;3=1;4=1;5=1;6=1;8=1;9=1;10=1
flags 0=1;3=1;39=1;40=1;42=1;50=1;55=1;94=1;107=1;113=1;114=1;123=1;160=1;165=1;1 66=1
state CS_REPORTING
direction inbound
state_number 11
Variables
Name Value
uuid 5874d3d6-349c-4dea-951f-4a7f255f73f3
billsec 0
waitsec 3
DP_MATCH 73731313627373131362
billmsec 0
billusec 0
duration 15
last_app bridge
last_arg sofia/gateway/cf16ef31-feb7-4bb8-a71e-dbd0954bdbed/7373131362
operator 1000
waitmsec 3381
waitusec 3380184
answersec 0
call_uuid 5874d3d6-349c-4dea-951f-4a7f255f73f3
caller_id "+13675006555" <+13675006555>
direction inbound
dtmf_type rfc2833
end_epoch 1733256355
end_stamp 2024-12-04 01:35:55
mduration 15120
read_rate 8000
sip_allow INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, REFER, NOTIFY
uduration 15120007
DIALSTATUS SUCCESS
answermsec 0
answerusec 0
end_uepoch 1733256355358918
read_codec PCMU
rtp_use_pt 0
session_id 40
sip_reason SIP;cause=487;text="ORIGINATOR_CANCEL"
sip_to_uri +12394566369@veronik-4cb956169622.sip.signalwire.com
write_rate 8000
bridge_uuid e034b491-99ae-4839-ae9a-59214dc836d5
domain_name azure.gpbx.com
domain_uuid 56cae3e8-9bcc-4909-b8bc-0841b8733ef5
export_vars call_direction,call_direction,rtp_secure_media,origination_callee_id_name,r tp_secure_media,call_direction,origination_callee_id_name
presence_id +13675006555@sip.signalwire.com
progresssec 0
signal_bond e034b491-99ae-4839-ae9a-59214dc836d5
sip_Privacy none
sip_call_id 34772432-ea19-4c0c-82e7-f9c41bfdf4b5
sip_full_to <sip:+12394566369@veronik-4cb956169622.sip.signalwire.com>
sip_gateway cf16ef31-feb7-4bb8-a71e-dbd0954bdbed
sip_req_uri gw+cf16ef31-feb7-4bb8-a71e-dbd0954bdbed@20.115.210.235:5060
sip_to_host veronik-4cb956169622.sip.signalwire.com
sip_to_user +12394566369
start_epoch 1733256340
start_stamp 2024-12-04 01:35:40
user_exists false
write_codec PCMU
RFC2822_DATE Wed, 04 Dec 2024 01:35:40 +0530
answer_epoch 0
bridge_epoch 1733256343
bridge_stamp 2024-12-04 01:35:43
channel_name sofia/internal/+13675006555@sip.signalwire.com
flow_billsec 0
hangup_cause ORIGINATOR_CANCEL
max_forwards 64
progressmsec 0
progressusec 0
rtp_use_ssrc 1667007964
sip_cid_type pid
sip_from_tag K1cZpKt9H3Q9r
sip_from_uri +13675006555@sip.signalwire.com
sip_full_via SIP/2.0/UDP 159.65.244.171:5060;branch=z9hG4bK984c.cf637402eebeb558d08589c894fe23b6.0;i =195d3,SIP/2.0/TLS 137.184.91.252:35181;received=137.184.91.252;rport=56463;branch=z9hG4bKtrQ0 g8rym44Zp
sip_req_host 20.115.210.235
sip_req_port 5060
sip_req_user gw+cf16ef31-feb7-4bb8-a71e-dbd0954bdbed
sip_via_host 159.65.244.171
sip_via_port 5060
start_uepoch 1733256340238911
switch_m_sdp v=0 o=SW 1733241175 1733241176 IN IP4 137.184.143.130 s=SW c=IN IP4 137.184.143.130 t=0 0 m=audio 15168 RTP/SAVP 0 101 13 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=rtpmap:13 CN/8000 a=ptime:20 a=crypto:1 AEAD_AES_256_GCM_8 inline:YejUy7AtecGAxL6oHuz0lFo8++o7HvaEA5mBKjMVTgRdnEJsLhuspinX+U0= m=audio 0 RTP/AVP 19
switch_r_sdp v=0 o=SW 1733243756 1733243757 IN IP4 137.184.91.252 s=SW c=IN IP4 137.184.91.252 t=0 0 m=audio 12584 RTP/SAVP 0 18 8 101 13 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=rtpmap:13 CN/8000 a=crypto:1 AEAD_AES_256_GCM_8 inline:6EcZilRtrLfAUMMh6xc+EecwbJjC3YhgrMmzkgIGybyPfa2fpkRmO5DoF1U= a=crypto:5 AES_256_CM_HMAC_SHA1_80 inline:s4aiGNQm2RN/fjyGE6lWJxqv05GMCpR4g19MArb0LPj15DZfSHoITubw56N9CA== a=crypto:7 AES_CM_128_HMAC_SHA1_80 inline:XxNisM67q4LJoZY6FjReQBRq+27eNJnrO6cneSTI a=crypto:8 AES_256_CM_HMAC_SHA1_32 inline:QOnhRGuR6m6C+9L+XNfb3XOeSnK54z0hZ4SA+jEz19ZL8mOcjufpc5lMeFkSFw== a=crypto:10 AES_CM_128_HMAC_SHA1_32 inline:6siwBVCMYnLkwD0/iT7NCOKPsC1k4I9OWP6mPbqv a=ptime:20 m=audio 12584 RTP/AVP 0 18 8 101 13 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=no a=rtpmap:8 PCMA/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=rtpmap:13 CN/8000 a=ptime:20
answer_uepoch 0
bridge_uepoch 1733256343619095
flow_billmsec 0
flow_billusec 0
hold_accum_ms 0
inherit_codec true
sip_from_host sip.signalwire.com
sip_from_user +13675006555
sip_full_from <sip:+13675006555@sip.signalwire.com>;tag=K1cZpKt9H3Q9r
valet_context azure.gpbx.com
bridge_channel sofia/internal/7373131362
call_direction outbound
caller_id_name +13675006555
do_not_disturb false
extension_uuid 1e123f50-2025-4497-afdf-ca6bdfff3337
last_bridge_to e034b491-99ae-4839-ae9a-59214dc836d5
local_media_ip 10.1.0.4
progress_epoch 0
rtp_has_crypto AEAD_AES_256_GCM_8
sip_authorized true
sip_network_ip 159.65.244.171
sip_req_params transport=udp;gw=cf16ef31-feb7-4bb8-a71e-dbd0954bdbed
sip_term_cause 487
sip_user_agent SignalWire
ep_codec_string CORE_PCM_MODULE.PCMU@8000h@20i@64000b,CORE_PCM_MODULE.PCMA@8000h@20i@64000b ,CORE_PCM_MODULE.PCMU@8000h@20i@64000b,CORE_PCM_MODULE.PCMA@8000h@20i@64000 b
hold_accum_usec 0
last_hold_epoch 0
originated_legs e034b491-99ae-4839-ae9a-59214dc836d5;+12394566369;7373131362
progress_uepoch 0
remote_media_ip 137.184.91.252
resurrect_epoch 0
sip_contact_uri mod_sofia@137.184.91.252:35181
sip_h_Diversion <sip:+13675006555@azure.gpbx.com>;reason=unconditional
sip_received_ip 159.65.244.171
sip_term_status 487
text_media_flow disabled
transfer_source 1733256340:69a83507-cd75-4e66-98d3-b714ea154a48:bl_xfer:7373131362/azure.ge niuspbx.com/XML
audio_media_flow sendrecv
callee_id_number 7373131362
caller_id_number +13675006555
continue_on_fail 1,2,3,6,18,21,27,28,31,34,38,41,42,44,58,88,111,403,501,602,607,809
from_user_exists false
last_bridge_role originator
last_hold_uepoch 0
local_media_port 32016
originate_causes e034b491-99ae-4839-ae9a-59214dc836d5;NONE
resurrect_uepoch 0
rtp_audio_in_mos 4.50
rtp_secure_media optional
sip_contact_host 137.184.91.252
sip_contact_port 35181
sip_contact_user mod_sofia
sip_invite_stamp 1733256340238911
sip_network_port 5060
sip_via_protocol udp
transfer_history 1733256340:5004ce86-928e-4331-8c36-ad66ccd05b64:bl_xfer:100/azure.gpbx .com/XML1733256340:69a83507-cd75-4e66-98d3-b714ea154a48:bl_xfer:7373131362/ azure.gpbx.com/XML
video_media_flow disabled
follow_me_enabled false
hangup_cause_q850 16
progress_mediasec 3
remote_media_port 12584
rtp_audio_recv_pt 0
rtp_local_sdp_str v=0 o=FreeSWITCH 1733224327 1733224328 IN IP4 20.115.210.235 s=FreeSWITCH c=IN IP4 20.115.210.235 t=0 0 m=audio 32016 RTP/SAVP 0 101 13 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-15 a=rtpmap:13 CN/8000 a=ptime:20 a=sendrecv a=crypto:1 AEAD_AES_256_GCM_8 inline:/SGADyWezTb7E9ppbHrYP+H+PEZ//MYNvHWDUVauIVuWHdCxQu07XFHtXfc= m=audio 0 RTP/AVP 19
sip_acl_authed_by providers
sip_received_port 5060
sofia_profile_url sip:mod_sofia@20.115.210.235:5060
caller_destination +12394566369
hold_accum_seconds 0
original_read_rate 8000
progress_mediamsec 3381
progress_mediausec 3380184
rtp_use_codec_name PCMU
rtp_use_codec_rate 8000
rtp_use_timer_name soft
sip_contact_params transport=tls;swrad=137.184.91.252~56463~3
sofia_profile_name internal
advertised_media_ip 20.115.210.235
bridge_hangup_cause ORIGINATOR_CANCEL
call_screen_enabled false
current_application bridge
forward_all_enabled true
hangup_after_bridge true
original_read_codec PCMU
profile_start_epoch 1733256340
profile_start_stamp 2024-12-04 01:35:40
rtp_use_codec_ptime 20
endpoint_disposition EARLY MEDIA
forward_busy_enabled false
profile_start_uepoch 1733256340318908
progress_media_epoch 1733256343
progress_media_stamp 2024-12-04 01:35:43
rtp_use_codec_string G7221@32000h,G7221@16000h,G722,PCMU,PCMA
sip_invite_route_uri <sip:159.65.244.171:5060;r2=on;lr;ftag=K1cZpKt9H3Q9r;nat=yes>,<sip:159.65.2 44.171:5061;transport=tls;r2=on;lr;ftag=K1cZpKt9H3Q9r;nat=yes>
originate_disposition SUCCESS
progress_media_uepoch 1733256343619095
recovery_profile_name internal
rtp_2833_recv_payload 101
rtp_2833_send_payload 101
sip_h_X-Relay-Call-ID 34772432-ea19-4c0c-82e7-f9c41bfdf4b5
ignore_display_updates true
remote_text_media_flow inactive
rtp_audio_in_raw_bytes 0
rtp_use_codec_channels 1
send_silence_when_idle -1
sip_from_user_stripped 13675006555
sip_hangup_disposition recv_cancel
sip_local_network_addr 20.115.210.235
sip_ph_X-Relay-Call-ID 2b633656-17dd-4240-b0ee-a6b2d0291b61
forward_all_destination 7373131362
outbound_caller_id_name +13675006555
remote_audio_media_flow sendrecv
remote_video_media_flow inactive
rtp_audio_in_flaw_total 0
rtp_audio_out_raw_bytes 0
sip_P-Asserted-Identity +13675006555
sip_invite_record_route <sip:159.65.244.171:5061;transport=tls;r2=on;lr;ftag=K1cZpKt9H3Q9r;nat=yes> ,<sip:159.65.244.171:5060;r2=on;lr;ftag=K1cZpKt9H3Q9r;nat=yes>
current_application_data sofia/gateway/cf16ef31-feb7-4bb8-a71e-dbd0954bdbed/7373131362
effective_caller_id_name +13675006555
rtp_audio_in_media_bytes 0
forward_no_answer_enabled false
outbound_caller_id_number +13675006555
rtp_audio_in_packet_count 0
rtp_audio_out_media_bytes 0
sip_invite_failure_phrase CANCEL
sip_invite_failure_status 487
effective_caller_id_number +13675006555
origination_callee_id_name +12394566369
rtp_audio_in_mean_interval 0.00
rtp_audio_out_packet_count 0
rtp_audio_rtcp_octet_count 0
rtp_secure_audio_confirmed true
proto_specific_hangup_cause sip:487
rtp_audio_rtcp_packet_count 0
rtp_last_audio_codec_string PCMU@8000h@20i@1c
rtp_secure_media_negotiated AEAD_AES_256_GCM_8
origination_caller_id_number +12394566369
rtp_audio_in_largest_jb_size 0
srtp_remote_audio_crypto_key 1 AEAD_AES_256_GCM_8 inline:6EcZilRtrLfAUMMh6xc+EecwbJjC3YhgrMmzkgIGybyPfa2fpkRmO5DoF1U=
rtp_audio_in_cng_packet_count 0
rtp_audio_in_jitter_loss_rate 0.00
srtp_remote_audio_crypto_type AEAD_AES_256_GCM_8
rtp_audio_in_dtmf_packet_count 0
rtp_audio_in_jitter_burst_rate 0.00
rtp_audio_in_skip_packet_count 587
rtp_audio_out_cng_packet_count 0
rtp_audio_in_flush_packet_count 0
rtp_audio_in_media_packet_count 0
rtp_audio_in_quality_percentage 100.00
rtp_audio_out_dtmf_packet_count 0
rtp_audio_out_skip_packet_count 0
rtp_last_audio_local_crypto_key 1 AEAD_AES_256_GCM_8 inline:/SGADyWezTb7E9ppbHrYP+H+PEZ//MYNvHWDUVauIVuWHdCxQu07XFHtXfc=
rtp_audio_in_jitter_max_variance 0.00
rtp_audio_in_jitter_min_variance 0.00
rtp_audio_in_jitter_packet_count 0
rtp_audio_out_media_packet_count 0
forward_user_not_registered_enabled false
Application Log
Name Data
export call_direction=inbound
set caller_destination= 12394566369
set caller_id_name= 13675006555
set domain_uuid=56cae3e8-9bcc-4909-b8bc-0841b8733ef5
set domain_name=azure.gpbx.com
set caller_id_number= 13675006555
transfer 100 XML azure.gpbx.com
set user_exists=true
set from_user_exists=false
set extension_uuid=1e123f50-2025-4497-afdf-ca6bdfff3337
set extension_caller_id_name=
set extension_caller_id_number=
set forward_all_enabled=true
set forward_all_destination=7373131362
set forward_busy_enabled=false
set forward_busy_destination=
set forward_no_answer_enabled=false
set forward_no_answer_destination=
set forward_user_not_registered_enabled=false
set forward_user_not_registered_destination=
set follow_me_enabled=false
set do_not_disturb=false
set call_timeout=30
set missed_call_app=
set missed_call_data=
set toll_allow=
set call_screen_enabled=false
set user_record=
set operator=1000
set rtp_secure_media=optional
export rtp_secure_media=optional
set valet_context=azure.gpbx.com
set outbound_caller_id_name=
set outbound_caller_id_number=
set outbound_caller_id_name= 13675006555
set outbound_caller_id_number= 13675006555
set origination_caller_id_number= 12394566369
set RFC2822_DATE=Wed, 04 Dec 2024 01:35:40 0530
export origination_callee_id_name= 12394566369
hash insert/azure.gpbx.com-last_dial/ 13675006555/100
eval not_secure
set sip_h_Diversion=<sip: 13675006555@azure.gpbx.com>;reason=unconditional
transfer 7373131362 XML azure.gpbx.com
set user_exists=false
set operator=1000
export call_direction=outbound
hash insert/azure.gpbx.com-last_dial/ 13675006555/7373131362
set sip_h_accountcode=
unset call_timeout
set hangup_after_bridge=true
set effective_caller_id_name= 13675006555
set effective_caller_id_number= 13675006555
set inherit_codec=true
set ignore_display_updates=true
set callee_id_number=7373131362
set continue_on_fail=1,2,3,6,18,21,27,28,31,34,38,41,42,44,58,88,111,403,501,60 2,607,809
bridge sofia/gateway/cf16ef31-feb7-4bb8-a71e-dbd0954bdbed/7373131362
