Hi there,
The "Limit Max" field in the Extension form says:
"Enter the maximum number of concurrent outbound calls allowed."
I have set this to 1, however I am still able to make multiple outbound calls through that extension.
I also have the max registrations set to 1, however I use Ringotel which is an intermediary so that allows multiple devices to be registered while only holding one registration on the server.
If Ringotel submits 2 outbound calls, though, shouldn't the second one be denied by this limit?
Thanks,
Iain
Thanks,
Iain
