least cost routing in fusionpbx
whut
359
46
How to implement least cost routing in fusionpbx?
I know you need to add the LCR module and that you need to load rate sheet(s). Where and how to you load rate sheets? What is the full implementation of LCR in fusionpbx?
I think it was a paid for module, but not a member application years ago. You'll probably have to reach out to Mark himself for this I guess.
Otherwise, the use FreeSWITCH mod_lcr and modify your outbound routes to bridge to the lcr application instead. This won't really be FusionPBX though, more just raw FreeSWITCH.
I know some people do it outside of FusionPNX with ASTPP. All calls will be sent to ASTPP trunk and then ASTPP will do the LCR.
I use a heavily customized version of pyfreebilling for years, that does LCR too.
