SOLVED Incoming Calls goes to voicemail
StanVaden
Good day!
I have a VM running Debian 9 with FusionPBX.
I'm by no means an expert. In fact I'm totally clueless when it comes to PBX. I'm trying to learn whilst providing my dad's business with a voip solution.
Anyways. I'm currently facing the strangest issue. My setup is as follows: <FusionPBX> <-> Internet <-> Router <-> Snom M215SC with two accounts
Whenever I reboot the system everything works great. Last night I turned her on and I was able to receive calls. This morning I was also able to make and receive calls. Now, Incoming calls go directly to voicemail. I've tried changing the signalling fron UDP to TCP and still I have no luck.
I've run the following:
sofia loglevel all 9
sofia global siptrace on
This is the results that I have:
https://pastebin.com/pUyj3uvC
Any help with figuring this out would be greatly appreciated.
JamesBorne
294
57
Australia
It's not strange at all actually. When you reboot, you are clearing your routers/firewalls sessions.
You are facing a networking issue; not one with the phones or PBX (which you can find the same reply to countless posts on this forum).
I would recommend lowering your register time to 120 and trying TCP as a first test.
