Running Fusion PBX ver 5.3 on Debian 12. Gateway is registered, outbound calls are fine and extension to extension is fine. However my DID cannot ring into the extension or Ring Group. I get a busy signal. My carrier is VoIPMS. See below for logfile output.
9af87540-2aa7-4d3c-9b06-f0ca56341343 2024-11-28 06:09:43.286933 87.00% [INFO] sofia.c:10460 sofia/internal/437xx627xx@208.100.60.55 receiving invite from 208.100.60.55:5060 version: 1.10.12-release git 7b80a9a 2024-11-23 23:59:58Z 64bit call-id: 44ac3728596640224173c55443518695@208.100.60.55:5060
2024-11-28 06:09:43.286933 87.00% [DEBUG] sofia.c:10554 verifying acl "providers" for ip/port 208.100.60.55:0.
9af87540-2aa7-4d3c-9b06-f0ca56341343 2024-11-28 06:09:43.306933 87.00% [DEBUG] switch_core_state_machine.c:600 (sofia/internal/437xx627xx@208.100.60.55) State NEW
2024-11-28 06:09:43.306933 87.00% [DEBUG] sofia.c:2419 detaching session 9af87540-2aa7-4d3c-9b06-f0ca56341343
2024-11-28 06:09:43.306933 87.00% [DEBUG] sofia.c:2532 Re-attaching to session 9af87540-2aa7-4d3c-9b06-f0ca56341343
9af87540-2aa7-4d3c-9b06-f0ca56341343 2024-11-28 06:09:43.326933 87.00% [INFO] sofia.c:10460 sofia/internal/437xx627xx@208.100.60.55 receiving invite from 208.100.60.55:5060 version: 1.10.12-release git 7b80a9a 2024-11-23 23:59:58Z 64bit call-id: 44ac3728596640224173c55443518695@208.100.60.55:5060
2024-11-28 06:09:43.326933 87.00% [DEBUG] sofia.c:10554 verifying acl "providers" for ip/port 208.100.60.55:0.
2024-11-28 06:09:43.326933 87.00% [WARNING] sofia_reg.c:3210 Can't find user [230xxx_Trunk@142.xx.76.xxx] from 208.100.60.55
You must define a domain called '142.xx.76.xxx' in your directory and add a user with the id="230xxx_Trunk" attribute
9af87540-2aa7-4d3c-9b06-f0ca56341343 2024-11-28 06:09:43.326933 87.00% [NOTICE] sofia.c:2417 Hangup sofia/internal/437xx627xx@208.100.60.55 [CS_NEW] [CALL_REJECTED]
