How to limit concurrent calls per domain just use for extension to extension calls?
lizz850517
Is there any way to set the limit of concurrent calls?
I'm using freeswitch/fusionpbx for multi-tenant(domains), and just use for internal calls in each domain(extension call extension)
I want to set different limit of concurrent calls for each domain, how am I suppose to do?
I've tried modify the max-session and sessions-per-second in "autoload_configs/switch.conf.xml" but it seems no works, and it seems global variable
also tried the call-limit in Dialplan Manager, still not works, I guess inbound and outbound are not use for internal calls in domain, not sure
Thanks in advance!
