How can I use ${sip_h_Referred-By} in an inbound dialplan?
ialmeida
Hi there,
So I'm new to FusionPBX, has been learning a lot the past few days.
The problem I'm facing is that a costumer wants to forward all calls from his cellphone directly to his extension, so I checked the INVITE with sngrep and "discovered" there is a Referred-By header there containing the cellphone number, which I want to use to create the condition in the inbound route.
I read I could get the header by using ${sip_h_Referred-By}, but that specific header/variable doesn't show up in the "type" field of the inboud route. I've tried to manually change it, clicking in the XML button, but it errors out when saving.
Any tips would be very appreciated, thank you so much in advance,
Igor
410
Unless it's changed in newer versions of FusionPBX, you can just select any of the ${sip_ choices and then click on it to edit it to whatever you want. Screen shot below:
whut
207
19
You can do this more simply all gui. In your destination set conditions with corresponding actions.If call comes from my mobile #, then transfer to the call to extension 12345
ialmeida
That doesn't work as all transferred calls from his mobile shows the caller ID from who is calling him, not his cell number.
