--    Intructions:
--    Simply add an action to your emergency outbound route. Make sure
--    the order is higher than your bridge statement
--    Tag: action
--    Type: lua
--    Data: app.lua emergency_notify [to_email_address] [from_email_address]
--debug
    debug["info"] = false;
    debug["sql"] = false;
--include config.lua
    require "resources.functions.config";
    require "resources.functions.explode";
    require "resources.functions.trim";
    require "resources.functions.base64";
--get arguments
    to_email = argv[2];
    from_email = argv[3];
--check the missed calls
    function send_mail()
        --set the sounds path for the language, dialect and voice
            default_language = session:getVariable("default_language");
            default_dialect = session:getVariable("default_dialect");
            default_voice = session:getVariable("default_voice");
            if (not default_language) then default_language = 'en'; end
            if (not default_dialect) then default_dialect = 'us'; end
            if (not default_voice) then default_voice = 'callie'; end
        --prepare the files
            file_subject = scripts_dir.."/app/emergency_notify/resources/templates/"..default_language.."/"..default_dialect.."/email_subject.tpl";
            file_body = scripts_dir.."/app/emergency_notify/resources/templates/"..default_language.."/"..default_dialect.."/email_body.tpl";
            if (not file_exists(file_subject)) then
                file_subject = scripts_dir.."/app/emergency_notify/resources/templates/en/us/email_subject.tpl";
                file_body = scripts_dir.."/app/emergency_notify/resources/templates/en/us/email_body.tpl";
            end
        --prepare the headers
            headers = '{"X-FusionPBX-Domain-UUID":"'..domain_uuid..'",';
            headers = headers..'"X-FusionPBX-Domain-Name":"'..domain_name..'",';
            headers = headers..'"X-FusionPBX-Call-UUID":"'..uuid..'",';
            headers = headers..'"X-FusionPBX-Email-Type":"emergency_call"}';
        --prepare the subject
            local f = io.open(file_subject, "r");
            local subject = f:read("*all");
            f:close();
            subject = subject:gsub("${caller_id_name}", caller_id_name);
            subject = subject:gsub("${caller_id_number}", caller_id_number);
            subject = subject:gsub("${sip_to_user}", sip_to_user);
            subject = subject:gsub("${caller_destination}", caller_destination);
            subject = trim(subject);
            subject = '=?utf-8?B?'..base64.encode(subject)..'?=';
        --prepare the body
            local f = io.open(file_body, "r");
            local body = f:read("*all");
            f:close();
            body = body:gsub("${caller_id_name}", caller_id_name);
            body = body:gsub("${caller_id_number}", caller_id_number);
            body = body:gsub("${sip_to_user}", sip_to_user);
            body = body:gsub("${caller_destination}", caller_destination);
            body = body:gsub(" ", " ");
            body = body:gsub("%s+", "");
            body = body:gsub("\n", "");
            body = body:gsub("'", "'");
            body = body:gsub([["]], """);
            body = trim(body);
        --send the email
            cmd = "luarun email.lua "..to_email.." "..from_email.." "..headers.." '"..subject.."' '"..body.."'";
            if (debug["info"]) then
                freeswitch.consoleLog("notice", "[emergency call] cmd: " .. cmd .. "\n");
            end
            api = freeswitch.API();
            result = api:executeString(cmd);
    end
--handle originate_disposition
    if (session ~= nil and session:ready()) then
        uuid = session:getVariable("uuid");
        domain_uuid = session:getVariable("domain_uuid");
        domain_name = session:getVariable("domain_name");
        context = session:getVariable("context");
        caller_id_name = session:getVariable("outbound_caller_id_name");
        caller_id_number = session:getVariable("caller_id_number");
        sip_to_user = session:getVariable("sip_to_user");
        caller_destination = session:getVariable("caller_destination");
        if (debug["info"] == true) then
            freeswitch.consoleLog("INFO", "[emergency_notify] caller_id_number: " .. tostring(caller_id_number) .. "\n");
            freeswitch.consoleLog("INFO", "[emergency_notify] caller_destination: " .. tostring(caller_destination) .. "\n");
            freeswitch.consoleLog("INFO", "[emergency_notify] to_email: " .. tostring(to_email) .. "\n");
            freeswitch.consoleLog("INFO", "[emergency_notify] from_email: " .. tostring(from_email) .. "\n");
        end
        send_mail();
    end
