Group Manager does not work
papsgrey
Hi All
On my fusionpbx when add a new group under group manager and tweak it then apply it to a user the permission
I enable don't show. it only shows the permissions of a regular user. image attached.
Hi.
Yes, I have assigned the menus.
For example, I have assigned the same menus as the administrator account.
I found some things:
1. When copying a profile (admin -> admin2), the table "v_group_permissions" does not change the value of "group_name" from admin to admin2
2. After changing the values manually in the table. From the web "group permissions" I can change the values of "Account Settings" but I cannot do it with the "User Manager"
The above when copying a profile, now document create a new one
Groups were not designed to change the name. If you want a new name create a new group.
@markjcrane it's ok
Only with the copy button this is possible.
When copying it should allow assigning a new name, but it does not, assign it.
Try changing and modifying in database to understand the problem. Although it's not the way
When creating a new profile "other2", I can only assign permissions up to "Email Templates"
For all others it does not save the changes
Well, I have the same issue and in my case the solution was found looking at /var/log/nginx/error.log
[error] 32350#32350: *41141 FastCGI sent in stderr: "PHP message: PHP Warning: Unknown: Input variables exceeded 1000. To increase the limit change max_input_vars in php.ini. in Unknown on line 0" while reading response header from upstream, client:
The number of variables exceed the default limit in php.ini, so just increase to 3000 and dont forget to restart php-fpm service to apply.
It's done.
Reactions: markjcrane
