Hi All,
I was given some advice to take a look at Fusion. (Currently using 3CX). After some initial testing and mistakes I have some questions....
1. Using a cloud based setup Vultr/OVH etc. Do you still need Internal Interface if using just WAN IPv4 address. Is it better to also have internal network also on server? (something I don't normally bother with)
2. How do remote phones at the office for example work with NAT ports and routing back to phones if they are also behind local router. With 3cx we have to use a SBC which routes via one port.
3. Do you guys change the default ports for security and what impactions does this have on the system.
4. Security concerns and steps to take as a minimum.
5. Changing the 'Cluecon' password seems to break things (socket errors) Ie can't load SIP status for example.
6. Provisioning seems hit and miss. Yealink which are normally very easy would not work on UDP and had to change to Tcp for some reason.
I know its a long list, but thanks to anybody who takes the time to respond! Its great to hear from real experience in these matters...
