Fax Problems
ee55
Just set up fusionpbx for faxing, using flowroute as sip trunk provider. Faxes keep failing with Unexpected DCN while waiting for DCS or DIS message. I believe the baud rate needs to be forced to 9600 for all faxes, and ECM turned off per flowroute recommendation. How exactly can i do this with fusionpbx/freeswitch configs?
inbound or outbound?
