Fanvil Provisioning Profiles and Keys
OISOwz
Hi All,
Would appreciate some insight into the provisioning templates and perhaps a pointer in the right direction! Using Fanvil X4G's and provisioning profiles just don't work for me. Also found reference to https://www.pbxforums.com/threads/yealink-t19p-e2.2585/ which sounds identical so assume these are relating to provision profiles against devices and not having the correct variables! The keys in template certainly don't reference to the variables.
Tried looking through other provisioning templates however could not work out the reference to keys or how the profiles are applied or referenced.
Anyone able to shed some light on this?
Owen
OISOwz
Nothing pushed to repo, I am also still working on template however the recent push by killsudo assisted with sorting out function keys. Though I have had to change the Fanvil vendor profile to get correct X4G values as are different from X5G / X6.
Also found there is no field to allow new vendor entries to have a Label?? Can anyone else confirm this is the same for them? They display blank on the selection list against devices so have had to update the originals and leave the blanks there for reference in event originals are overridden.
  • X4G_template.txt
screwloose
Edit the /var/www/fusionpbx/app/devices/app_languages.php file make a $text['label-X4G_call_forward']['en-us'] = "X4g Call Forward";
screwloose
To Add Headset Button
1) add line $text['label-headset']['en-us'] = "Headset"; to /var/www/fusionpbx/app/devices/app_languages.php
3) Edit the provisioning template
<Extern5PageBelong>0</Extern5PageBelong>
<internal index="1">
{foreach $keys['line'] as $row}
{if $row.device_key_id == '9'} <internal index="2">{/if}
{if $row.device_key_id == '18'} <internal index="3">{/if}
{if $row.device_key_id == '27'} <internal index="4">{/if}
{if $row.device_key_id > '8'} {$row.device_key_id = $row.device_key_id -8} {/if}
{if $row.device_key_id > '17'} {$row.device_key_id = $row.device_key_id -17} {/if}
{if $row.device_key_id > '27'} {$row.device_key_id = $row.device_key_id -26} {/if}
<Fkey index="{$row.device_key_id}">
<Type>{$row.device_key_type}</Type>
{if $row.device_key_type == '3'} <Value>{$row.device_key_value}</Value>{/if}
{if $row.device_key_type == '1'} <Value>{$row.device_key_value}@1/bc</Value>{/if}
<Title>{$row.device_key_label}</Title>
<ICON>Green</ICON>
</Fkey>
{if $row.device_key_id == '8'}</internal>{/if}
{if $row.device_key_id == '17'}</internal>{/if}
{if $row.device_key_id == '26'}</internal>{/if}
{/foreach}
<dssSoft index="1">
This is work in progress. As issues come up i'm tweaking the settings. Not sure how to best get this out there.
Also you need to add the buttons in the same amount at is on the screen. (unless some on know how to make the code always count up to 8 or 6)
