I have a failed socket connection error.
When I spin up a Hetzner server, I have event socket errors, but when I use my vultr server I do not get these errors.
This is on a brand new install of 5.3 fusionpbx on a dedicated VPS with Hetzner. I get socket connection failed errors. Debian 12
On Vultr with the same install of 5.3 I don't get errors. Same os Debian 12
On the Hetzner server with a fresh install of 5.3 today, freeswitch cannot be found. When I try to restart freeswitch it says it can't be found.
During the install on the Hetzner VPS, the last few lines have errors. I don't get these error when installing on a fresh copy of Fusion on Vultr.
Mar 31 19:40:19 andrewbyrdnetworks systemd[1]: freeswitch.service: Scheduled restart job, restart counter is at 8.
Mar 31 19:40:19 andrewbyrdnetworks systemd[1]: Stopped freeswitch.service - freeswitch.
Mar 31 19:40:19 andrewbyrdnetworks systemd[1]: freeswitch.service: Start request repeated too quickly.
Mar 31 19:40:19 andrewbyrdnetworks systemd[1]: freeswitch.service: Failed with result 'exit-code'.
Mar 31 19:40:19 andrewbyrdnetworks systemd[1]: Failed to start freeswitch.service - freeswitch.
cp: target '/var/www/fusionpbx/app/switch/resources/scripts/wakeup.lua': Not a directory
cp: target '/usr/local/share/freeswitch/languages': No such file or directory
App Defaults Executed
INSERT 0 1
INSERT 0 1
Upgrade
Database
Schema: No Change
Job for freeswitch.service failed because the control process exited with error code.
See "systemctl status freeswitch.service" and "journalctl -xeu freeswitch.service" for details.
Created symlink /etc/systemd/system/multi-user.target.wants/email_queue.service → /etc/systemd/system/email_queue.service.
Created symlink /etc/systemd/system/multi-user.target.wants/event_guard.service → /etc/systemd/system/event_guard.service.
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
cron is already the newest version (3.0pl1-162).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
no crontab for root
