Export CDR Format wrong timezone
Naveed Ur Rehman
Hi
I am facing issue that when on cdrs page, it shows the data in correct timezone. but when i export the CDRs, it shows the timezone as GMT +8:00. I have set system time to UTC, and also freeswitch time using UTC timezone. Please advise someone how to fix this issue. on other server, with default settings, i cam geetting CDRs exported as UTC.
Regards
Naveed
whut
207
19
@paulczichos is correct. Start by checking whether or not you have the correct timezone set in default settings. This will be more important than the timezone of the server's operating system timezone. You have not described where you have set timezone to UTC. There are multiple locations you can set this, 2 of which are noted here in my reply.
