Recently we've discovered that DTMF tones on external calls are sent from an endpoint in our system are short and "poor quality" and tend to double up like you pressed the button twice.
We've tested multiple phones and ATAs and it doesn't seem to change. Internal tones seem to work just fine.
We've searched and tried a few things but anything tried hasn't helped. Any suggestions appreciated.
We tried changing DTMF modes on the ATAs with no real change in the behavior.
What it appears to do is the system is getting the DTMF signal from the endpoint, Fusion recieves it and then spits it back out, but I think the end user is hearing both.
Below are some logs when pressing a few digits if it helps.
Any suggestions? Thanks much!
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:04.491677 [DEBUG] switch_rtp.c:5261 Send start packet for [3] ts=1583525451 dur=160/160/2000 seq=59342 lw=1583525451
43ec852b-b250-4083-846c-c161a1aff0ff digit=3 ms=250 samples=2000
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:04.491677 [DEBUG] switch_channel.c:611 sofia/internal/102@tenant.domain.tld Queue dtmf
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:04.491677 [INFO] switch_channel.c:515 RECV DTMF 3:2000
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:04.491677 [DEBUG] mod_dptools.c:132 sofia/internal/102@tenant.domain.tld Digit NOT match binding [3]
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:04.491677 [DEBUG] switch_rtp.c:7534 RTP RECV DTMF 3:1600
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.571653 [DEBUG] switch_rtp.c:5108 Queue digit delay of 40ms
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.571653 [DEBUG] switch_rtp.c:5160 Send end packet for [6] ts=1583516171 dur=2080/2080/2000 seq=59307 lw=1583517931
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.571653 [DEBUG] switch_rtp.c:5160 Send end packet for [6] ts=1583516171 dur=2080/2080/2000 seq=59306 lw=1583517931
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.571653 [DEBUG] switch_rtp.c:5160 Send end packet for [6] ts=1583516171 dur=2080/2080/2000 seq=59305 lw=1583517931
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.551650 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=1920/1920/2000 seq=59304 lw=1583517931
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.531644 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=1760/1760/2000 seq=59303 lw=1583517771
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.511639 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=1600/1600/2000 seq=59302 lw=1583517611
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.491669 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=1440/1440/2000 seq=59301 lw=1583517451
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.471673 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=1280/1280/2000 seq=59300 lw=1583517291
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.451678 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=1120/1120/2000 seq=59299 lw=1583517131
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.431645 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=960/960/2000 seq=59298 lw=1583516971
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.411654 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=800/800/2000 seq=59297 lw=1583516811
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.391658 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=640/640/2000 seq=59296 lw=1583516651
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.371643 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=480/480/2000 seq=59295 lw=1583516491
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.351645 [DEBUG] switch_rtp.c:5160 Send middle packet for [6] ts=1583516171 dur=320/320/2000 seq=59294 lw=1583516331
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:31:03.331655 [DEBUG] switch_rtp.c:5261 Send start packet for [6] ts=1583516171 dur=160/160/2000 seq=59293 lw=1583516171
43ec852b-b250-4083-846c-c161a1aff0ff digit=6 ms=250 samples=2000
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:03.331655 [DEBUG] switch_channel.c:611 sofia/internal/102@tenant.domain.tld Queue dtmf
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:03.331655 [INFO] switch_channel.c:515 RECV DTMF 6:2000
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:03.331655 [DEBUG] mod_dptools.c:132 sofia/internal/102@tenant.domain.tld Digit NOT match binding [6]
43ec852b-b250-4083-846c-c161a1aff0ff 2020-12-11 03:31:03.331655 [DEBUG] switch_rtp.c:7534 RTP RECV DTMF 6:1600
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:30:56.811646 [DEBUG] switch_rtp.c:5108 Queue digit delay of 40ms
f553a521-7445-406c-a976-7bc99c69b4d4 2020-12-11 03:30:56.811646 [DEBUG] switch_rtp.c:5160 Send end packet for [5] ts=1583
