Dial out | Pattern | Prepend e164 | help
adrnandes
32
Hi there,
My provider Twilio expects to receive the number in E164 format, for example, +44xxxxxxxxxx.
So, I need to adjust the rules in fusionpbx, Dashboard, to rearrange the numbers, in cases where the user dials in the following ways: +44, +440, 00, 01, 02, 03, 05, 07, 09, 084, 087, 0800, the number must be adjusted and arrive at Twilio in the E164 format.
Fusionpbx 5.3 version.
Any help please?
Thank you.
dcitelecom
153
To convert all numbers to e.164 format use the following but forget the + sign. Twilio does not need it and it will only cause problems.
In your Outbound Route, you would use a condition statement for your destination number with Regex like
^(?:0044|00|44|440|01|02|03|05|07|09|084|087|0800)?(\+?[2-9]\d{10,17})$
to first strip away all the numbers you do not want and then add the 44 or +44 country back to the dial string in your Action Bridge to Twilio
sofia/gateway/Provider-Name/44$1
0044207123456789 -> 207123456789
440207123456789 -> 207123456789
01207123456789 -> 207123456789
adrnandes
32
Hi dcitelecom,
Thank you very much for your help.
I couldn't get it to work with your regular expression, but it inspired me on how to diagnose and find a way to make it work, so I adapted it to the configuration below, and now it's working.
And in my scenario, it was necessary to use the +.
Thank you.
UK Numbers Regular Expression | Twilio | FusionPBX 5.3
^(?:0044|00|44|440|\+44|0)?([1-9]\d{8,15})$
sofia/gateway/Twilio/+44$1
