I am facing an unusal issue on Fresh FusionPBX install, I tried to re-install but receiving the same error, Whenever call the Incoming DID that is assigned in the FusionPBX i get the below error. I did not edit any XML files, this is a Fresh Install of Fusion.
Fusionpbx Version : 4.5.17
Switch Version : 1.10.5 (64bit)
Freeswitch Version: 1.10.5
Calling Number : +91931974XXXX
DID (Destination number) : 1833370XXXX
Domain : sub.domain.com - this is an actual domain, the extensions are getting registered without any issues.
[ERR] switch_xml.c:1761 Error[[error near line 153]: missing >]
[WARNING] mod_dialplan_xml.c:667 Context sub.domain.com not found
2020-09-13 17:41:13.369775 [NOTICE] switch_channel.c:1118 New Channel sofia/internal/+91931974XXXX@1.1.1.1 [18a36f0b-5727-45b1-a097-384071034d9e]
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/+91931974XXXX@1.1.1.1) Running State Change CS_NEW (Cur 1 Tot 33)
2020-09-13 17:41:13.369775 [DEBUG] sofia.c:10280 sofia/internal/+91931974XXXX@1.1.1.1 receiving invite from 1.1.1.1:5060 version: 1.10.5 -release-17-25569c1631 64bit
2020-09-13 17:41:13.369775 [DEBUG] sofia.c:10374 verifying acl "domains" for ip/port 1.1.1.1:0.
2020-09-13 17:41:13.369775 [DEBUG] sofia.c:10403 IP 1.1.1.1 Approved by acl "domains[]". Access Granted.
2020-09-13 17:41:13.369775 [DEBUG] sofia.c:7326 Channel sofia/internal/+91931974XXXX@1.1.1.1 entering state [received][100]
2020-09-13 17:41:13.369775 [DEBUG] sofia.c:7336 Remote SDP:
v=0
o=FreeSWITCH 1599984143 1599984144 IN IP4 1.1.1.1
s=FreeSWITCH
c=IN IP4 1.1.1.1
t=0 0
m=audio 27530 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=ptime:20
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[G722:9:8000:20:64000:1]
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:5649 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:5594 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:5510 Set telephone-event payload to 101@8000
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:3839 Set Codec sofia/internal/+91931974XXXX@1.1.1.1 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2020-09-13 17:41:13.369775 [DEBUG] switch_core_codec.c:111 sofia/internal/+91931974XXXX@1.1.1.1 Original read codec set to PCMU:0
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:5853 Set telephone-event payload to 101@8000
2020-09-13 17:41:13.369775 [DEBUG] switch_core_media.c:5911 sofia/internal/+91931974XXXX@1.1.1.1 Set 2833 dtmf send payload to 101 recv payload to 101
2020-09-13 17:41:13.369775 [DEBUG] sofia.c:7760 (sofia/internal/+91931974XXXX@1.1.1.1) State Change CS_NEW -> CS_INIT
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:604 (sofia/internal/+91931974XXXX@1.1.1.1) State NEW
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/+91931974XXXX@1.1.1.1) Running State Change CS_INIT (Cur 1 Tot 33)
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/+91931974XXXX@1.1.1.1) State INIT
2020-09-13 17:41:13.369775 [DEBUG] mod_sofia.c:93 sofia/internal/+91931974XXXX@1.1.1.1 SOFIA INIT
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:40 sofia/internal/+91931974XXXX@1.1.1.1 Standard INIT
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:48 (sofia/internal/+91931974XXXX@1.1.1.1) State Change CS_INIT -> CS_ROUTING
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:628 (sofia/internal/+91931974XXXX@1.1.1.1) State INIT going to sleep
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/+91931974XXXX@1.1.1.1) Running State Change CS_ROUTING (Cur 1 Tot 33)
2020-09-13 17:41:13.369775 [DEBUG] switch_channel.c:2332 (sofia/internal/+91931974XXXX@1.1.1.1) Callstate Change DOWN -> RINGING
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/+91931974XXXX@1.1.1.1) State ROUTING
2020-09-13 17:41:13.369775 [DEBUG] mod_sofia.c:154 sofia/internal/+91931974XXXX@1.1.1.1 SOFIA ROUTING
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:236 sofia/internal/+91931974XXXX@1.1.1.1 Standard ROUTING
2020-09-13 17:41:13.369775 [INFO] mod_dialplan_xml.c:637 Processing +91931974XXXX <+91931974XXXX>->1833370XXXX in context public
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 parsing [public->caller-details] continue=true
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Regex (PASS) [caller-details] () =~ // break=never
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action export(call_direction=inbound) INLINE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 export(call_direction=inbound)
2020-09-13 17:41:13.369775 [DEBUG] switch_channel.c:1310 EXPORT (export_vars) [call_direction]=[inbound]
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action set(caller_destination=${sip_to_user}) INLINE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 set(caller_destination=1833370XXXX)
2020-09-13 17:41:13.369775 [DEBUG] mod_dptools.c:1672 SET sofia/internal/+91931974XXXX@1.1.1.1 [caller_destination]=[1833370XXXX]
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 set(caller_id_name=+91931974XXXX)
2020-09-13 17:41:13.369775 [DEBUG] mod_dptools.c:1672 SET sofia/internal/+91931974XXXX@1.1.1.1 [caller_id_name]=[+91931974XXXX]
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action set(caller_id_number=${caller_id_number})
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 parsing [public->18555272753] continue=false
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Regex (FAIL) [18555272753] destination_number(1833370XXXX) =~ /^(1855527XXXX)$/ break=on-false
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 parsing [public->18662160304] continue=false
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Regex (FAIL) [18662160304] destination_number(1833370XXXX) =~ /^(1866216XXXX)$/ break=on-false
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 parsing [public->18882275723] continue=false
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Regex (PASS) [1833370XXXX] destination_number(1833370XXXX) =~ /^(1833370XXXX)$/ break=on-false
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action set(domain_uuid=566b8efb-7db3-4921-a56d-e4a9ffa43196) INLINE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 set(domain_uuid=566b8efb-7db3-4921-a56d-e4a9ffa43196)
2020-09-13 17:41:13.369775 [DEBUG] mod_dptools.c:1672 SET sofia/internal/+91931974XXXX@1.1.1.1 [domain_uuid]=[566b8efb-7db3-4921-a56d-e4a9ffa43196]
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action set(domain_name=sub.domain.com) INLINE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 set(domain_name=sub.domain.com)
2020-09-13 17:41:13.369775 [DEBUG] mod_dptools.c:1672 SET sofia/internal/+91931974XXXX@1.1.1.1 [domain_name]=[sub.domain.com]
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action set(hangup_after_bridge=true) INLINE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 set(hangup_after_bridge=true)
2020-09-13 17:41:13.369775 [DEBUG] mod_dptools.c:1672 SET sofia/internal/+91931974XXXX@1.1.1.1 [hangup_after_bridge]=[true]
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action set(continue_on_fail=true) INLINE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 set(continue_on_fail=true)
2020-09-13 17:41:13.369775 [DEBUG] mod_dptools.c:1672 SET sofia/internal/+91931974XXXX@1.1.1.1 [continue_on_fail]=[true]
Dialplan: sofia/internal/+91931974XXXX@1.1.1.1 Action transfer(1000 XML sub.domain.com)
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:287 (sofia/internal/+91931974XXXX@1.1.1.1) State Change CS_ROUTING -> CS_EXECUTE
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/+91931974XXXX@1.1.1.1) State ROUTING going to sleep
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/+91931974XXXX@1.1.1.1) Running State Change CS_EXECUTE (Cur 1 Tot 33)
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/+91931974XXXX@1.1.1.1) State EXECUTE
2020-09-13 17:41:13.369775 [DEBUG] mod_sofia.c:209 sofia/internal/+91931974XXXX@1.1.1.1 SOFIA EXECUTE
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:329 sofia/internal/+91931974XXXX@1.1.1.1 Standard EXECUTE
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 set(caller_id_number=+91931974XXXX)
2020-09-13 17:41:13.369775 [DEBUG] mod_dptools.c:1672 SET sofia/internal/+91931974XXXX@1.1.1.1 [caller_id_number]=[+91931974XXXX]
EXECUTE [depth=0] sofia/internal/+91931974XXXX@1.1.1.1 transfer(1000 XML sub.domain.com)
2020-09-13 17:41:13.369775 [DEBUG] switch_ivr.c:2243 (sofia/internal/+91931974XXXX@1.1.1.1) State Change CS_EXECUTE -> CS_ROUTING
2020-09-13 17:41:13.369775 [NOTICE] switch_ivr.c:2250 Transfer sofia/internal/+91931974XXXX@1.1.1.1 to XML[1000@sub.domain.com]
2020-09-13 17:41:13.369775 [DEBUG] switch_core_state_machine.c:651 (sofia/internal/+91931974XXXX@1.1.1.1) State EXECUTE going to sleep
2020-09-13 17:41:13.369775 [DEBUG] mod_sofia.c:145 Call appears to be already acknowledged
2020-09-13 17:41:13.369775 [INFO] mod_dialplan_xml.c:637 Processing +91931974XXXX <+91931974XXXX>->1000 in context sub.domain.com
2020-09-13 17:41:13.389734 [ERR] switch_xml.c:1761 Error[[error near line 153]: missing >]
2020-09-13 17:41:13.389734 [WARNING] mod_dialplan_xml.c:667 Context sub.domain.com not found[/B]
2020-09-13 17:41:13.389734 [INFO] switch_core_state_machine.c:312 No Route, Aborting
2020-09-13 17:41:13.389734 [NOTICE] switch_core_state_machine.c:313 Hangup sofia/internal/+91931974XXXX@1.1.1.1 [CS_ROUTING] [NO_ROUTE_DESTINATION]
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:644 (sofia/internal/+91931974XXXX@1.1.1.1) State ROUTING going to sleep
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/+91931974XXXX@1.1.1.1) Running State Change CS_HANGUP (Cur 1 Tot 33)
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:848 (sofia/internal/+91931974XXXX@1.1.1.1) Callstate Change RINGING -> HANGUP
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/+91931974XXXX@1.1.1.1) State HANGUP
2020-09-13 17:41:13.389734 [DEBUG] mod_sofia.c:453 Channel sofia/internal/+91931974XXXX@1.1.1.1 hanging up, cause: NO_ROUTE_DESTINATION
2020-09-13 17:41:13.389734 [DEBUG] mod_sofia.c:598 Responding to INVITE with: 404
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:60 sofia/internal/+91931974XXXX@1.1.1.1 Standard HANGUP, cause: NO_ROUTE_DESTINATION
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:850 (sofia/internal/+91931974XXXX@1.1.1.1) State HANGUP going to sleep
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:620 (sofia/internal/+91931974XXXX@1.1.1.1) State Change CS_HANGUP -> CS_REPORTING
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:585 (sofia/internal/+91931974XXXX@1.1.1.1) Running State Change CS_REPORTING (Cur 1 Tot 33)
2020-09-13 17:41:13.389734 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/+91931974XXXX@1.1.1.1) State REPORTING
2020-09-13 17:41:13.429731 [DEBUG] switch_core_state_machine.c:174 sofia/internal/+91931974XXXX@1.1.1.1 Standard REPORTING, cause: NO_ROUTE_DESTINATION
2020-09-13 17:41:13.429731 [DEBUG] switch_core_state_machine.c:936 (sofia/internal/+91931974XXXX@1.1.1.1) State REPORTING going to sleep
2020-09-13 17:41:13.429731 [DEBUG] switch_core_state_machine.c:611 (sofia/internal/+91931974XXXX@1.1.1.1) State Change CS_REPORTING -> CS_DESTROY
2020-09-13 17:41:13.429731 [DEBUG] switch_core_session.c:1726 Session 33 (sofia/internal/+91931974XXXX@1.1.1.1) Locked, Waiting on external entities
2020-09-13 17:41:13.429731 [NOTICE] switch_core_session.c:1744 Session 33 (sofia/internal/+91931974XXXX@1.1.1.1) Ended
2020-09-13 17:41:13.429731 [NOTICE] switch_core_session.c:1748 Close Channel sofia/internal/+91931974XXXX@1.1.1.1 [CS_DESTROY]
2020-09-13 17:41:13.429731 [DEBUG] switch_core_state_machine.c:739 (sofia/internal/+91931974XXXX@1.1.1.1) Running State Change CS_DESTROY (Cur 0 Tot 33)
2020-09-13 17:41:13.429731 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/+91931974XXXX@1.1.1.1) State DESTROY
2020-09-13 17:41:13.429731 [DEBUG] mod_sofia.c:364 sofia/internal/+91931974XXXX@1.1.1.1 SOFIA DESTROY
2020-09-13 17:41:13.429731 [DEBUG] switch_core_state_machine.c:181 sofia/internal/+91931974XXXX@1.1.1.1 Standard DESTROY
2020-09-13 17:41:13.429731 [DEBUG] switch_core_state_machine.c:749 (sofia/internal/+91931974XXXX@1.1.1.1) State DESTROY going to sleep
