CDR - Call Detail Records
Andrew Byrd
317
11
When I delete records from the CDR in the GUI under Applications, does this delete the CDR and Recording off the entire server?
Just wondering if it only deletes the visual a the gui or if it really removes ALL
It removes the CDR from database and by default is the only place CDR would be found.
And recordings from a call are stored on the filesystem and would not be deleted from simply deleting a CDR record.
