CDR and Call recordings not working since rebuilt and restore
Tricky1024
25
I have just re-installed a new Debian 12 system and backed up and restored the system from another Debian 12 host.
everything is ok other than CDR reports are not working, dashboard shows no stats other than disk usage and call recording are not showing in GUI.
System is 5.1.0 stable
I have checked database and schema, applied app defaults, rebooted a few times
I can verify call recording though are recorded and placed in the correct directories so i think this is a database thing, maybe something in the restore from the old system.
Note the other system HAD NO CDR details as it was being used as a temp install as i manually re-created the system due to to many issues with the live one.
Nothing showing of any great interest in the access.log or error.log
Tricky1024
25
dont know if its relevant but i ONLY restored the database and didnt copy any folders over.
could be that the xml_cdr files cannot now access the new DB, maybe i need to copy over all the freeswitch and fusion folders including the config.conf?
Tricky1024
25
just restarted Freeswitch and get a warning for every domain:
2023-12-14 13:13:13.705398 100.00% [WARNING] switch_core.c:1644 Cannot locate domain <domain name>
could this be that i have restored the DB for fusionpbx but NOT the switch?
Tricky1024
25
restored the /etc/freeswitch directory and still not CDR, tried to restore /etc/fusionpbx but then i cannot access the DB.
any ideas? anyone?
Tricky1024
25
found it, nothing to do with the restore, Debian 12 on Azure did not install cron.!!! really. do the cron job was never created to complete the CDR import.
