i had tried following this tutorial on setting up inbound caller id from contacts:
hovewer it results to unknown for all callers including ones I have in contacts. I tried removing country code, switching between all 3 possible ones for given number (8, 0, +370) and tried including it in number itself but with no luck. Only thing I couldn't do exactly was
which returned following results:
I edited /var/www/fusionpbx/app/switch/resources/conf/autoload_configs/cidlookup.conf.xml in accordance to tutorial. Do anyone have this working?
Caller ID Lookup (cidlookup) from Contacts.
Time and time again those who are new to FusionPBX find it difficult to get cidlookup working from their contact list. Inbound Route: Now navigate to Advanced > XML Editor > autoload_configs > cidlookup.conf.xml and modify existing lines with these: Once you've finished the...
www.pbxforums.com
because there is no such option, but I didNow navigate to Advanced > XML Editor > autoload_configs > cidlookup.conf.xml and modify existing lines with these:
find / -name cidlookup.conf.xml
/usr/src/freeswitch-1.10.12/src/mod/applications/mod_cidlookup/conf/autoload_configs/cidlookup.conf.xml
/usr/src/freeswitch-1.10.12/conf/vanilla/autoload_configs/cidlookup.conf.xml
/etc/freeswitch.orig/autoload_configs/cidlookup.conf.xml
/etc/freeswitch/autoload_configs/cidlookup.conf.xml
