Call routing between several asterisk
VinZ
Edit : I dit it, all I was needing was gateways properly configured (no hostname in the hostname field !) and outbound routes (inside the proper context I guess).
Hi all,
I'm a complete newbie with fusionPBX and I'm having trouble with setting up what's probably the easiest case with it.
I got several asterisk servers up'n'running with number ranges allocated to them, and I'd like to have fusionPBX making the calls distribution :
if call received if for a number in range 1 --> send it to asterisk 1
if call received if for a number in range 2 --> send it to asterisk 2
and so on ...
Asterisk servers are set up as gateways in fusionPBX, and fusion is registered on them.
Asterisk are properly sending calls to fusion.
And up to now, it always ens in 404.
I'm not sure I'm supposed to configure a domain for each asterisk.
I'm not sure I have to configure inbound routes.
I'm pretty sure I have to configure outbound routes.
Do I need to configure the number ranges in the dialplan manager ? Or is it enough if I have them in the condition for outbound route ?
What am I supposed to do with the destinations ?
What's about that "context" which is everywhere but not in the documentation ? And where do I add/remove them ?
Feel free to send me RTFM, but if you do so, please provide a link to a good manual :)
